Ive tryed a few guides off the net. But im stuck at the un tarring of the actual torrent flux file that ive downloaded. Once ive downloaded it what do i do with itl
The easiest way to install it would be to enter: sudo apt-get install torrentflux This will install TorrentFlux and all of the dependencies. The configuration is web-based and very easy.
admin@*******:~$ tar -xvzf torrentflux_2.4.tar.gz tar: torrentflux_2.4.tar.gz: Cannot open: No such file or directory tar: Error is not recoverable: exiting now tar: Child returned status 2 tar: Error exit delayed from previous errors admin@********:~$ tar zxfv tar: Old option `f' requires an argument. Try `tar --help' or `tar --usage' for more information. admin@******:~$ is what ive tried, obviously a problem with the torrent flux file
Nope, there's a problem with you It needs to be in your Home directory, not on your desktop which is where I am guessing it is! Move it and that command will work
