Hi all,
I need some advice with regard to my current PC and what&when to upgrade to give me good performance in VR/1440p ultra wide. Its base build was 2012 and pretty much been left alone apart from the removal of 2x 7970s and the installation of the 980ti.
It was all originally water-cooled however I've removed this although it can be reused with the correct parts in the future (air cooling works very well and often I'm not in the same room so noise is not an issue).
Current specs:
Realistically I'm wanting to get the best bang for the buck which is why I'm considering a motherboard/CPU/RAM upgrade initially and seeing how this performs with the 980ti - if I still have issues either look for a deal on a 2070s/2080s/5700XT which should tide me over for at least two years?
New Spec
My basket at Overclockers UK:
This seems to be the best set of components for my requirement, however - should I buy the graphics card first and upgrade the above list at a later date, if so what kind of bottleneck is my CPU & Ram going to create?
Thanks,
Current specs:
- i5 3570k @ 4.2
- Gigabyte Z77X D3H
- 256GB SSD & 512GB SSD
- Silverstone Strider Plus 750W Modular '80 Plus Silver' Power Supply
- Kingston HyperX Genesis Grey 8GB
- Zalman Midi Case
- Zotac GeForce GTX 980Ti AMP Omega Edition 6144MB GDDR5 @ +20 Core & +340 Mem
- 34" QHD ultra wide monitor
- Coolermaster Hyper 212 cooler
- Oculus Quest connects via virtual desktop (wifi) or link cable to play Steam VR games/ Oculus.
New Spec
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £109.99
- 1 x Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit (PVS416G360C7K)= £98.99
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £179.99
Thanks,
