1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Using 27" iMac screen as a monitor for a PC
Discussion in 'Apple Hardware' started by johnrs, 7 Mar 2010.
  1. johnrs
    Gangster
    Hi.
    recently sold all my PC kit for a lovely new 27" iMac. On the whole no regrets, and I thought for the few games I want to play the 4850 would be OK.
    I have been doing some searching on how to connect a PC to the 27" iMac's display port, but I cannot find anything concrete, that's to say someone who has achieved this and documented what they did, what cable they used and what GFX card was used.
    All I seem to be able to find is people trying this with very little success
    Anyone here tried this or seen any threads about this. had a look on here but could not seem to find what I am looking for. Also posted this on the macrumors site too.
    Cheers
  2. tenshin111
    To be honest I was considering getting myself the 27" iMac too and use it as a screen for another computer(PC)....Have you tried a Display Port to DVI adapter? I think Apple sells their own adapters. As far as I am concerned, you also need to have the iMac turned on...even if you want to use it as a screen only. Not the most convenient solution...
  3. Slackworth
    Capodecina
  4. johnrs
    Gangster
    Hi, my son has a 5770 which has DVI, HDMI and also a display port on it. I have Mini DP to DVI adapter from when I had my MBP, but that did not work. from what I have just read on the apple forum is that you will need a DP to M-DP cable which I am trying to see where its sold in the UK
  5. tenshin111
    Good to know...In this case I'm no longer interested :(
  6. johnrs
    Gangster
    has anyone seen a UK seller for a display port to mini DP cable?
  7. Raikiri
    Capodecina
    I just found one in about 10 seconds for £5.50. Just Google "displayport to mini displayport" and go to products.
    To be fair, most new cards will have DisplayPort. The entire 5xxx range does and I'm sure Fermi will.
  8. tenshin111
    Didn't realise that. Well, if I get myself a Radeon 5850 I will probably reconsider this idea :D
  9. johnrs
    Gangster
    Cheers. I have seen the error of my way and have found them. Cheers
    I am going to order one and try it on my sons ATI 5770
  10. tenshin111
    Let us know if it works then! :)
  11. wakayoda
    Wise Guy
    why don't you get a decent large display instead of buying a MAC then only using the screen?
  12. JediFragger
    Caporegime
    A large display plus a Mac Mini might be a good option :)
  13. Spyhop
    That 27" display is pretty high end - AFAIK there's not much comparable spec-wise.
  14. johnrs
    Gangster
    I already have an iMac and don't really want to sell it for a pc. I have got a cable coming on Tuesday so will see what happens then
  15. MossyUK
    Wise Guy
    I asked this question a while back on a mac forum and was told the iMac can't be used as an external display :(
    It would be awesome as a gaming screen for my gaming PC and as my work station screen all the other time.
    Please keep this thread update with how you get on, this could persuade me to imac land.
  16. johnrs
    Gangster
    The cable should be here today so I will update this post later when I get home
    I have read on a few other forums that it can be done so fingers crossed, but might depend on your GFX card
  17. johnrs
    Gangster
    OK. cable arrived and plugged in and low and behold, nothing. While dissapointed I am not surprised.
    This is what happens.. do the CMD + F2 screen goes black, I hear the 2 tone noise that Win7 makes when it finds new hardware and thats ya lot...
    Not sure if this is a Apple Feature or an ATI Feature, but this statement take from apple Features Page about the iMac is not quite true
    Mini DisplayPort.
    The Mini DisplayPort lets you connect an external display, including the Apple LED Cinema Display, to your iMac. On the 27-inch iMac, the same port offers input, too. So you can connect any external source that has DisplayPort output — including a MacBook or MacBook Pro — and use your iMac as a display
  18. EVH
    Don
    .....in OS X.
  19. johnrs
    Gangster
    Not sure I understand what you mean?
    EDIT: if your refering to the 2 tone sound, thats coming from the speakers of the PC when I do CMD F2 on the mac
  20. Fozzie55
    Gangster
    An adapter is out that lets you connect your Xbox 360 or PS3 to the iMac screen so I would have thought a PC would work.
