Yah, just a bit .basmic said:it is ever so slighty dangerous.
If you are, the saltpeter is way to coarse and is burning slowly. Use fine saltpeter, it will burn faster and give a better bang.Rich1988 said:might be using gunpowder
Potato tbh, nothing else really fits the bill. You'll want it so that the potato forms a seal with the sides of the pipe for best effects.Rich1988 said:I am working on projectiles really which veggie is best XD
Zip said:Get a BIG potatoe and cut it to size so it fits, U can also make it more Aero Dynaminc by cutting it right
Raikiri said:*wonders how long until a large nail is put through the potato*
Then you could use a dart board as a target
