Thought that would get your attention!
My Virgin ADSL broadband wasn't connectable on Sunday evening and again last night. My Netgear router DG834GT had a flashing orange 'i' symbol indicating no ADSL service. The service starts again automatically in the morning.
Virgin have confirmed their service was fine on Sunday and I got the usual generic response. I've tried different cables, phone point, power adapter etc. without luck.
BT's dslchecker confirms the service is poor in my area (see report below).
A year ago I left BT for a similar problem and joined Virgin, so I don't think it is an ISP problem. I'm at the end of the exchange so maybe get worse problems when it is overloaded.
I'd appreciate your advice whether to persevere and maybe buy a newer router to rule this out.
Or alternatively look into mobile broadband. Problem here is that I get a very poor signal across all networks (no mobile signal indoors on O2, Orange and Vodafone).
Thanks, John
THE BROADBAND AVAILABILITY CHECKER
For Telephone Number 01382581XXX on Exchange MUIRHEAD
Your exchange is ADSL enabled, and our initial test on your line indicates that it is VERY UNLIKELY you will be able to receive fixed 512Kbps or 256Kbps broadband service due to the very long length of your telephone line. However, your order will be accepted if you still wish to order. An engineer may need to visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports a potential ADSL Max broadband line rate of 250Kbps or greater.
If you decide to place an order, a further test will be performed to confirm if your line is suitable for the service you wish to purchase.
Thanks, John
