I Have a set of creative gigaworks s750 7.1 speakers for my htpc which don't have a digital audio input, just the 4 3.5mm jacks
I've just got a virgin plus box which I want to connect to the speakers properly, ideally without the PC having to be on all the time but I think the only way i can do it is to get a better sound card with optical in to connect it to the pc and play it through there.
Is there a fancy device in existance that can convert the audio output from the V+ box to the 3 audio jacks for the speakers without the pc being on?
If not, i was looking at getting a creative x-fi card, I'm told that the £30 odd one doesnt actually have the new processor, so does the x-fi titanium have this to take sound processing away from the CPU.
If i went with the sound card upgrade, had the V+ box connected to the tv with the hdmi for video, and then to the sound card via optical in, should it all work ok and in 5.1/7.1 sound (where programs use it)?
Cheers
Dave
Cheers
Dave
