Voipcheap with a Linksys SPA3000 - VoIP-In okay?
27 Aug 2003
My VoIP-In phone number only seems to ring when it feels like it! If I reset the ATA then it works but seems to "drop off" after a short time.
Is anyone else experiencing similar problems with the above setup?
OP
27 Aug 2003
OllyM said:
Sounds like a firewall problem - I guess you're using NAT...
Have you got a STUN server set in the config for the SPA?
Thanks for the reply.
Yes, I'm have NAT enabled on my NETGEAR DG834G.
I'm just looking for the "STUN server" option in the SPA3000 UI - I can't find it dude! :(
Sorted now thanks - I just needed to set "NAT Keep Alive Enable" to yes :cool:
