1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
VX220 Lights Repair
Discussion in 'Motors' started by Muncher, 29 May 2006.
  1. Muncher
    Following on from the thread about my car being keyed, I repaired both of my rear lights this weekend.
    The nearside rear had a scratch all the way across it, about 1.5mm deep, very visible and easily catches your nail as your pass your finger across it. The offside one was scratched about an inch too.
    I bought a MicroMesh perspex repair kit from an aircraft supplier who sell them for removing scratches from aircraft canopies. It consists of a foam block, 6 different grades of MicroMesh which is a special fabric based wet abrasive, 2 cotton wipes and some MicroMesh finishing compound.
    The kit said to use coarse wet and dry paper, down to 220 grade to remove traces of the scratch, I opted for a more cautious 400 grade. That took about an hour to do both lights, the key is to do it slowly and to reove all traces whatsoever.
    Next, starting with the most course MicroMesh, rub only in one direction for a few minutes, I did 3 passes of each light, wiping it down in between. Repeating for all grades, eventually ending at 6000 grade, which is about as coarse as A4 paper...
    Finally rubbing using half of the cloth wipe in one direction, using quite a bit of pressure with the cloth wrapped tightly round the block. After a few minutes rubbing the lights were looking pretty damn good, though still some scratches left though.
    So I then got the Mer scratch repair drill attachment out and put a plastic bag over it, the cloth then tied and taped it together. I then went over the lights a couple of times using a fairly low speed and just the end of the pad, finally washed them and the results are below. They are pretty much optically perfect which I'm quite happy with.
    http://www.muncher.org.uk/lights
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Gaijin
    Don
    Bloody great result sir! Well done :)
  3. agw_01
    Capodecina
    :eek:
    Wow! That's amazing work! What I want to know is how the hell does sand paper end up making a surface smooth and shiny like that.
    Top job :cool:
  4. timbob
    Mobster
    Top job!
    I'm very impressed with the way you've undertaken all this repair work yourself, in your own time, with miniumal experience, turning out excellent results. Given the circumstances surrounding the initial damage, it's been an excellent attitude to take - hats off!
  5. Memphis
    Capodecina
    Great stuff dude, job well done!
    I'd have been craping myself at the first stage thinking what the hell have I done to my lights!
  6. Scottland
    Capodecina
    That looks a top job, you fitted it back in yet?
    How's the car now, is there much (if any) left over from the incident?
  7. Burned_Alive
    Capodecina
    This is why i really fear having a nice car, someone else always ruins it. Excellent work there though mate!
  8. F355
    Mobster
    Excellent :D
    I have used that micromesh stuff before. Its good at getting scratches out of watch faces too.
  9. Muncher
    The paintwork repair is still in its early stages, I'm away for a week so will crack on when I get back. I made a few early attempts, and stopped to revise for my finals after covering with a rough, thick layer of paint.
    They're not back on the car yet, they're just drying out then I'm going to seal both with mastic while they're off, to prevent any leaks.
    The initial sandpaper is what you'd expect, but the MicroMesh is like leather, even the most coarse grade is still extremely smooth.
  10. S@njay
    Mobster
    very impressed!
    And look on the good side, with all this slight sanding, your car will be slightly lighter than other cars in the class!
    I need to get rid of some scratches in my car, one of my rear arches got keyed :( Cant wait to do it, only after i finish my final exams thou.
    I guess as long as you have the paitents, you can have a great result!
  11. TripleT
    Sgarrista
    Looking great mate :)
    Really admire your paticence, I'd have got angry, broken something, and then just paid for it to be fixed by now! :o :p
  12. Tesla
    Capodecina
    Cracking job there, really looks the business.
    How is the paint work at the moment?
  13. eidolon
    Capodecina
    Excellent job Muncher, they look better than new!!
  14. AmDaMan
    Mobster
    Awsome mate well done! How many man hours have you spent on the lot so far?
  15. Muncher
    Too many to count, 25ish on the paint in bits and pieces.
    About 5 hours on the lights.
  16. olv
    wow, impressive finish!
  17. Gilly
    Man of Honour
    I still need to sort out the keying my car got when I was on the liverpool meet. Had a mate's mate trying to fit me in but he's well busy. Would only cost £15 there :/
    nice work Muncher
