1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
W7 to W7 Remote Desktop not working
Discussion in 'Windows & Other Software' started by Meatball, 19 Feb 2010.
  1. Meatball
    My house network consists of:
    Netgear WNR2000 Router
    Windows Home Server (WHS2003, Connected via ethernet)
    Conservatory PC (Windows 7, Connected via Ethernet)
    Laptop (Windows 7, Connected via Wireless-N)
    Whenever I try and remote desktop Windows 7 to Windows 7 it never works, I get the following error:
    [​IMG]
    I can however remote desktop Windows 7 to WHS2003 fine. All the W7 PC's have remote desktop enabled and I have the remote desktop port enabled on my router.
    [​IMG]
    Any ideas? :)
  2. IAmATeaf
    What firewall software are you running, with KIS you have to put the local network into the known or trusted group before I can get a connection established.
  3. Meatball
    KIS2010. I'm sure I've selected my network as 'Trusted' but cannot find the menu.
    EDIT: found it. This is the screenshot from my Windows 7 laptop connected via Wifi, which is shown as 'Trusted'.
    [​IMG]
  4. Dreadhead
    Gangster
    Try disabling Kaspersky for the time being to see if that is causing the issue.
  5. Meatball
    No difference with Kaspersky completely closed :(. It still confuses me as I can remote desktop between Windows 7 and Windows Home Server fine, without changing anything. It's only between Windows 7 and Windows 7.
  6. IAmATeaf
    Have you added users to the Remote Desktops group?
  7. Daegan
    Wise Guy
    What version of Windows 7 are you running?
  8. Meatball
    Added users?
    Windows 7 Home Premium x64 :)
  9. Skeeter
    Caporegime
    Home Premium doesnt have Remote Desktop Server. You cannot Remote Desktop into a HP machine, you can only use the client to Remote Desktop out to another machine.
    Unless its been hacked (ive got a Vista HP with a hacked RDC Server DLL in it) you will have to find another way to remotely connect.
  10. dirk_diggler
    PermaBanned
    Cool , I wasn't even aware home editions supported rdp
  11. Meatball
    You're joking! That throws a spanner in my network plans, I knew I should have pre-ordered Professional :(.
  12. Skeeter
    Caporegime
    They dont. They only support the client, which is just a connection to another machine, and is available on all sorts of OS's, including Linux and mobile phones. The the server software you need to be able to remotely control a machine and only Professional, Business, Enterprise or Ultimate editions of Windows since XP have had it.
  13. Skeeter
    Caporegime
    Yes, because you are using the client software on Windows 7 to connect to the Remote Desktop server software in WHS. Windows 7 doesnt have the server part in it, so you cannot connect to a Window 7 HP machine as there is nothing for the client to connect to.
    Its like a Web Browser and a Web Server. Anything with a web browser can connect to a web site, but just because you have a browser installed doesnt mean other people can connect to your machine.
  14. Meatball
    Well that solves the mystery then! I'll know for when Windows 8 arrives to buy the cheapest that offers Server functionality!
  15. Skeeter
    Caporegime
    If its anything like XP, Vista and 7 it will be the cheapest business aimed one.
    Im searching now, but it doesnt look like RDC Host has been hacked into 7 HP yet...
  16. masterluke
    Wise Guy
    you can just install a vnc server if you wanted, not as fast as RDP but will work just fine
  17. Meatball
    I'll take a look into that, thanks :).
    Thanks for the help gents.
  18. dirk_diggler
    PermaBanned
    I suggest you try to ultravnc flavour of vnc :)
  19. Skeeter
    Caporegime
    If you want easy setup free access to your machines away from home over the internet Log Me In is great (logmein.com)
  20. Dreadhead
    Gangster
    +1, LogMeIn also supports Wake Over Lan, which is incredibly useful if you don't want the controlled machine on all the time.
