1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
water cooled 470 480 gtx?
Discussion in 'Graphics Cards' started by andyuk1, 14 Apr 2010.
  1. andyuk1
    Gangster
    hi,is there a 470,480gtx watercooled edition on its way to order or do u have to get a seperate waterblock for it?
  2. Phoenixdancer
    PermaBanned
    No and Yes but none out yet... Buy a 5970 :p
  3. andyuk1
    Gangster
  4. Liampope
    Mobster
    How about...
    Standard 480
    [​IMG]
    Sorry...
  5. andyuk1
    Gangster
    say if i got a 5970 card and want to water cool it.i will get a waterblock for it.how do i connect the temp monitor to my mother board.does it come with a black lead as well?
  6. jrwagh333
    andyuk1 to answer your question. There will be separate blocks available. Also I know EVGA is releasing a ForTheWin edition of their 480 & 470 cards. Overclocked & with a water block already fitted.
    Not sure if OcUK are getting these in or not
  7. Razor Time
    Mobster
    EVGA have wattercooled Fermi's, details on their site. Also Koolance, Dangerden, Inno3D and EK all have blocks for Fermi. Just check out all their websites for details.
    Its always cheaper to buy a stock card and put your own waterblock on, rather than buy a card which already has a block on.
  8. andyuk1
    Gangster
    ok chaps,thanks for info.just looking and i am gonna try this set up .this card http://www.overclockers.co.uk/showproduct.php?prodid=GX-214-AS with a waterblock.but how do u measure the temp of the card.with my old 8800gtxwatercooled it had a lead from the card to the motherboard.will it have it on the waterblock itself.sorry but never upgraded before and want to get this right.Also is it hard to swap the fan to a block.
  9. Razor Time
    Mobster
  10. andyuk1
    Gangster
    thanks razor,u got a good setup.crysis looks super.i should be able to cope now.do u need to put paste on the block as well to make the contact.or just the card.
  11. RavenXXX2
    Capodecina
  12. Razor Time
    Mobster
    Thanks andy. :)
    Only put the Tim on the actual card, you dont need to apply it to the block. Once you have installed the block remove it to make sure all chips have made contact, reapply it and then your good to go. :)
  13. mmj_uk
    Caporegime
    There will be some watercooled ones available soon, after spending £400+ it's probably not a good idea to void the warranty fitting a waterblock.
  14. RavenXXX2
    Capodecina
    Buy an EVGA card and the warranty covers removing the stock cooler.
  15. Razor Time
    Mobster
    If you buy an EVGA card the warranty allows the removal of the cooler.
    Watercooled cards normally sell for about £200 more.
