1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
water cooling
Discussion in 'Overclocking & Cooling' started by GTA767, 16 May 2010.
  1. GTA767
    Gangster
    ok today i got my evga ssc 480 so now i want water cooling
    going to buy this one what u think guys?
    i like pump and resevoir cause i have antec 900 good cable manegment and it will perfectly fit in bay
    [​IMG]
  2. Higadeb
    Gangster
    I like it, I would change a couple of things:
    1) Use 1/2" barbs with that tubing for a ridiculously tight seal, no leaks here! You may even need to warm up the tube slightly to mold it over the barbs.
    2) I would look at a Thermochill PA 120.3 Just my personal preference and I know from first hand experience that the PA series is very good, I would never use anything different.
  3. tipes
    Mobster
    Agreed - Thermochill PA 120.3 for the win, best out there I reckon.
  4. HW91
    Wise Guy
    swap the XT for an EK supreme HF, cools a bit better and costs less.
    also change the tubing clips for metal worm clips, they hold better for a longer time
  5. stiv121
    Wise Guy
    +1 for the thermochill rad.
  6. tipes
    Mobster
    Good idea - have the EK supreme - great bit of kit.
  7. GTA767
    Gangster
    ok ordered thermochill 480 as i am going to add gtx 480 for sli after september
  8. Higadeb
    Gangster
    I have the EK Supreme HF too. It's a very good block. The only thing I would say is that the XT is actually supposed to be 1-2'C better. It's really a choice on whether the extra cost is really worth it. Also, there have been some reports of XT's arriving dead or with severely limited performance and having to be replaced. Not sure how much truth is in this though.
