1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
What microATX motherboard for HTPC ?
Discussion in 'Motherboards' started by Snow-Munki, 20 May 2006.
  1. Snow-Munki
    Capodecina
    Hi,
    was just wondering what you guys reccomend for a microATX motherboard for an HTPC machine.
    there are soo many around so not sure what to choose, haven't got CPU yet so socket does n't matter atm, just the price :)
  2. hp7909
    Any motherboards with NVIDIA 6150/6100 GPU are good, i.e. apart from a decent graphics chip, they've got SATA2, etc. Most ppl here will recommend Asus A8N-VM CSM :)
  3. Snow-Munki
    Capodecina
    thanks for the quick reply, how about the ATI ones, seem a few of those around.
  4. hp7909
    Don't know much about those one's i'm afraid. Got interested in the NVIDIA one's because they claim Windows Vista Ready with that GPU!
  5. Sumanji
    Sgarrista
    Check out my GeForce 6150 thread :) it should be sticky'ed really... :p
    Suman
  6. squiffy
    Banned
    Asus CSM board is good, onboard managed 1080p. Fine unless you need multiple PCI card (tuner, radio etc)
  7. p4radox
    Capodecina
    The Asus is a very good board, as is the Foxconn 6150 based board. If you want to have a go at overclocking look into the Biostar TForce 6100 mobo. It has loads of options and the best overclocks on mATX boards have been obtained on the Biostar.
    The DFI RS482 Infinity is another very capable option, but difficult to source in the UK.
  8. Snow-Munki
    Capodecina
    oh, i was going to get the MSI one, the one you have not mention, no good ?
  9. p4radox
    Capodecina
    I've not really had any experience of it, nor heard anything about it. I've had good solid MSI boards in the past though so it should be fine. :)
    Are you going to overclock?
  10. Snow-Munki
    Capodecina
    naa, as long as it is stable that's all that matters. just going to be my media pc.
    the one i'm on now is for gaming :D ( operton 146 @ 2.9ghz
  11. squiffy
    Banned
    Which Silverstone case? I looked at a few of them, all the MATX desktop cases have low profile, not enough for PCI and PCIE cards to be used. Purchased the TJ07, granted not HTPC looking but enough space. HD cage bit of a pain to fit HD, but apart from that ok. 7v modded case fans, 1600rpm CPU. Pretty quiet.
    [​IMG]
    The Asus has DVI out, the MSI doesn't. But the MSI has optical header port.
  12. Snow-Munki
    Capodecina
    squiffy, you talking to me ??
    As i have a coolermaster htpc case, desktop style but yeah pretty cramp.
    oh and have double checked the MSI one does have DVI if you get the better version.
  13. david25
    Hitman
  14. gr1mey
    Wise Guy
    I take it that with the mATX board with inbuilt GPU's its fairly easy to disable them and use a normal PCIx16 GFX board?
  15. james.miller
    Capodecina
    yup. you dont even have to disable them. My ati xpress200 board has an x300 onboard. It played very happily together with my gto2 for multi screen goodness.
    ....shame i only have one monitor lol
  16. squiffy
    Banned
    I hope so, otherwise what's the point of the PCI-E slot? :) I think my BIOS does have a disable option. If not just don't install the Nivida graphics driver and disable it in device manager.
  17. james.miller
    Capodecina
    yeah most boards thesedays should have the option. Althouh i have come across boards that have absolutely no way of turning it off.
  18. gr1mey
    Wise Guy
    the other thing that concerns me is the north/southbridge heatsinks - Ive an x800xl with an ATI Silencer fitted I want to put on the mATX board - will these interfere?
  19. david25
    Hitman
    I have an HIS x800xl in my Asus n4lvm-dh board, no problems with space (bios auto disables the built-in vga)
    I think its the cheapest core board around.
  20. DiscoKandy
    Hitman
    Are the onboard Graphics on the Asus board suitbale for a 32" HDTV, read on other forums that a GeForce 7300 is recommended for HDTV
