1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Which CPU Cooler is best (under 50£) for Intel Core 2 DUO E6600
Discussion in 'Overclocking & Cooling' started by PESolution, 22 Jul 2006.
  1. PESolution
    Mobster
    Hi, im about to purchase a new rig with a Intel Core 2 DUO E6600 2.4ghz. Was wondering which CPU cooler you would suggest i get. Or when i purchase the CPU will a cooler come with it? Thanks in advance :)
  2. Slogan
    Do you plan to overclock?
  3. PESolution
    Mobster
    Yes, but not to extreme levels.
  4. trojan698
    ThermalTake Big Typhoon! :)
  5. hp7909
    Intel don't do OEM chips, so HSF should be included.
    But from the thread's/etc I’ve been reading, supplied HSF is not very quiet & efficient (if overclocking). As replacement, the Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY) keeps on being mentioned/recommended/ordered/etc :D
  6. PESolution
    Mobster
    thanks for the replies guys, the sycthe one looks cool, tht defs ok for conroe?
  7. Jimbo
    Just get a Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR) .
  8. smids
    It's not a question of if it ok for Conroe, more of, will it fit your motherboard. It should do but sometimes capacitors etc get in the way of it fitting - but I believe Scythe's pretty much fit most mobo's/cases.
  9. silversurfer
    Capodecina
    Theres an oem conroe cpu in the ocuk shop but it still comes with hsf just a reduced 1 year guarantee I think
  10. cobxx
    Gangster
    Big typhoon or the freezer 7 pro are the most popular choices around here. From the look of things though, it doesn't look as if the conroe's are super hot, but the freezer 7 pro is dirt cheap anyway!
  11. Virdi
    Mobster
    AC Freezer 7 Pro.
    This is a top cooler for the money.
  12. Jimbo Mahoney
    There's an OEM 6300.
  13. hp7909
    :o just seen it :D
    Intel are really going after AMD's enthusiast market :eek:
