rite i have a amd 64 4400+ dual core a asus AR8 MVP motherboard , and need to choose some ram now the one i wanted was Corsair (TWINX2048-3200C2PT) 2GB (2 x 1GB Matched Pair) DDR PC3200 2x128Mx64 non-ECC 2x184 DIMM unbuffered 2-3-3-6 64Mx8 DRAMs Matched Pair Silver Heat Spreader Lifetime Warranty but this seams to be out of stock on, so is this much better or worse OCZ (OCZ4002048ELDCPE-K) 2 x 1 Gb EL DDR PC-3200 Dual Channel Platinum OCZ Platinum Edition PC-3200 memory is specifically designed for ultra-low latency timing operation on both Intel and AMD chipset based motherboards. OCZ Platinum Edition PC-3200 memory is able to reach latencies as low as CL 2-3-2-5 or even lower depending on the specific motherboard! Every Dual Channel Kit from OCZ is hand tested as a matched pair across a wide variety of motherboards to ensure flawless performance on most motherboards. comes with a high quality copper heat spreader with a Platinum mirrored finish OCZ Platinum Edition memory modules are rated to handle up to 2.8V without invalidating the OCZ Lifetime Warranty so that performance enthusiasts can tweak their systems without worry! or is there something else i should go for i want 2 gb and no more than £145ish inclduing vat any help would be great should i wait, What do i do lol ! thanks in advance ! !! LIAM
The platinum is £164.44 inc vat, but is better than the corsair you mentioned. The quicker timing mean it will literally be quicker.
Not really, all others in the same league are more money. The OCZ platinum is the best currently available for the price IMO.
