1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
will my pioneer A09xls silver panel fit on a new 110D ?
Discussion in 'Optical Storage & Writing' started by bledd, 27 Jan 2006.
  1. bledd
    Don
    Want 16x burning and good looks
  2. Bigpops
    Mobster
    The 109 is 16x :confused:
    Seriously, unless you want DVD-RAM writing capability, then there's not really any point swapping it.
    I also have the 109xls, and i can't fault it. It's my fourth Pioneer writer (after 104, 107 and 108) and i haven't had any trouble with this or any of the others.
  3. Bigpops
    Mobster
    Now, as per your question... I doubt it'll be a straight swap. You may be able to do it with some modification.
  4. bledd
    Don
    oops
    needed another dvdrw for my mce pc, was going to put the 'best' one into my silver case, ill just stick with the 109 for now then :)
