1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
wireless adaptor causing 100% cpu load
Discussion in 'Networks & Internet Connectivity' started by Ish, 13 Jul 2006.
  1. Ish
    Wise Guy
    Hi
    I have a netgear wpn311 wireless pci card in my pc. The problem I have is that even on idle it is causing a 80-100% cpu usage. If i disable the adaptor the cpu usage drops right down. Any ideas?
    I have a amd64 3000 processor with 1gb of ram.
  2. theredguy
    Banned
    Could be a driver issue try updating them if possible.
  3. Ish
    Wise Guy
    i have already tried using lastest driver
