- 25 Jul 2005
Hi guys,
Just after a recommendation/feedback regarding the following;
Had sky installed at the beginning of the week. The house already has the first floor cabled for network, so to put the sky hub upstairs makes everything easy.
However, this then leaves no connectivity downstairs, only wifi. TV, PS3 are both wifi capable, so that's no issue. The problem is getting Internet connection to the sky box for on demand services.
Sky make/sell what they call a "wireless connector" which is what I understand to be a wireless bridge.
So;
For only £21.95 the sky connector seems best value for money, does anybody know if this is/isn't wireless N and if they are any good?
If I plug this into a switch, I guess I can then wire the sky box, PS3 & TV all getting connection via the wireless connector?
Alternatively, are there any other products that you would recommend (homeplug, wireless bridge etc...) and why?
Many thanks
So;
Many thanks
