1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Wireless Repeaters
Discussion in 'Networks & Internet Connectivity' started by bfar, 15 Jun 2006.
  1. bfar
    Wise Guy
    I'm having trouble connecting to a wireless router - its really annoying, cause its not that far away from the client, only about 10 - 15 metres. Everything works, its just out of range. The signal is a bit smothered because of the geography of the place. I can't move the router or the client.
    Would it be worth getting a repeater of some sort, and can anyone recommend one? Or is there an easier solution, like a better antenae?
  2. mattreay
    Best bet is a better ariel. I picked two up for about £15 from ebay and managed to connect my AP to my friends PC over the road through several outer walls still at 11mbps.
