1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
WRT54G work with a ADSL line?
Discussion in 'Networks & Internet Connectivity' started by Xplode, 14 Aug 2006.
  1. Xplode
    Hitman
    Hi all
    I have recently moved out and have a ADSL broadband via BT i was wondering would my Linksys WRT54G work with the ADSL line??
    Talking to a networking bud said if i pluf the ethernet cable into user 1 instead of the internet port the connection will get shared? Is this right?
    Or do i have to buy a ASDL router?
    Thanks
    Andy
  2. dirtydog
    PermaBanned
    Do you mean you have an ADSL modem to work in conjunction with the router? Because otherwise no, you need a router which has a built-in ADSL modem.
  3. Xplode
    Hitman
    Yer i have a ADSL modem and want to use my already owned WRT54G router with it?
    I have tried connecting the ethernet cable into the internet line in port on the router but that didnt work.
  4. dirtydog
    PermaBanned
    I don't see how it would work, unless your ADSL modem doesn't require you to 'dial-up' to establish a connection?
  5. Xplode
    Hitman
    yer the ADSL modem doesnt need to dial up.
    A friend has said that if i put the ethernet cable from the modem into the first port then i will be able to share the connection!?
  6. errata
    Wise Guy
    How many computers do you want to attach?
    Which adsl modem? Is it a pure modem or a modem router?
    It should be possible but your going to have to configure both devices correctly.
    We need more info
