1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
x1800 replacement
Discussion in 'Graphics Cards' started by DarkWhisper, 20 Feb 2010.
  1. DarkWhisper
    Hitman
  2. Marine-RX179
    Capodecina
    The CPU would probably be the limiting factor...the chances are the 5870 would provide only around the same performance and frame rate as a 5770 because of the CPU holding it back.
    Here's some data for your reference:
    Test kits: HD5870, 4GB Corsair 800Mhz DDR2, 4GB Corsair 1,600Mhz DDR3
    Crysis (DirectX 10, 64-Bit, High) at 1,680x1,050
    [email protected] (stock speed)=12-35fps
    Q6600 [email protected]=24-45fps
    [email protected] (stock speed)=19-36fps
    E8400 [email protected]=27-48fps
    Phenom II X4 965 BE (C3 stepping) @3.4Ghz (stock speed)=23-46fps
    Phenom II X4 965 BE (C3 stepping) [email protected] =29-52fps
    Core i5 [email protected] (stock speed)=20-50fps
    Core i5 750 [email protected] (stock speed)=33-57fps
    (source: Custom PC Issue 078 March 2010, p41)
    Unless you are going to upgrade the CPU as well, you'd probably be better off just get a 5770 instead.
  3. DarkWhisper
    Hitman
    no the 5770's running on that spec
  4. Marine-RX179
    Capodecina
    Ah sorry I thought I saw a 5870 when I clicked on the link. 5770 seems like a sensible choice.
    I think I should go sleep now as my eyes is clearly not seeing things right.
  5. DarkWhisper
    Hitman
    You can only wish to have a 5870 at 120 pound
  6. stulid
    Capo Crimine
    If your not bothered about directX11, a ati4890 is faster.
  7. Marine-RX179
    Capodecina
    In most modern PC with faster CPU...yes, but with that Athlon 64 X2 6400, even the slightly slower 5770 can probably only deliver around 80-95% of its max capability at most, so a 4890 would most likely not be any faster, plus lacking dx 11.
  8. stulid
    Capo Crimine
    Reviews say otherwise.
  9. DarkWhisper
    Hitman
    Will there is the up side of overclocking it to 900/1300
