1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
x1900 series and power supply
Discussion in 'Graphics Cards' started by NaNd0!, 26 Jul 2006.
  1. NaNd0!
    Gangster
    Quick q.. regarding the power hungry ati x1900xtx cards... would the following enermax liberty 400w psu be ok?
    http://www.enermax.co.uk/products/psu/liberty/ELT400AWT/spec.asp
    key specs..
    DC Output Rating
    +3.3V 26A 150W
    +5V 28A
    +12V1 20A 360W (30A)
    +12V2 20A
    +3.3V, +5V, +12V1, +12V2 Combined 377.8W
    -12V 0.6A 22.2W
    +5Vsb 3A
    Total Power 400W
    the pc il be using the card in has essentially a fx60cpu, 4x512mb of ballistix ram, 2x 300gig sata hdd's, nec dual layer dvd writer, pci 7.1 sound card.
    also.. you reckon crossfire with 2 of the ati cards would be poss using this psu?
    Ta v much :)
  2. Cyber-Mav
    Capodecina
    it shoudl handle it. not sure about running 2 x1900xtx cards. but those 12v rails do seem to have a lot of current on them.
  3. NaNd0!
    Gangster
    sweet cheers for the pronto reply.. some more feedback from others would be great also.
    ta.
  4. freddib
    that something ive been wanting to know as well
    i ordered the liberty 500watt with my x1900xt to make sure
    check here to work out your power requirements and add some
    extra watts to make sure
    http://www.extreme.outervision.com/psucalculator.jsp
    my system works out about 320watt but if i add ageing into the calculations it jumps to 410watt also i think 35amps is the recomended amount for sli
    not sure about xfire
  5. semi-pro waster
    Man of Honour
    The 400w is, I believe, slightly lower than the manufacturers recommendations for an X1900XT, however it ought to be capable of running the system but you will probably be near the limit. As for Crossfire, I wouldn't. It might run but you would almost certainly be pushing your PSU to its limit and possibly beyond. If you can afford the rest of the hardware you can afford £70-100 on a decent 500w+ PSU, there is no point skimping on such an essential item.
    If your system has got what is effectively an FX60(and not an actual FX60) then you must be overclocking which demands more from a PSU than just running at stock would obviously.
  6. Johny Boy
    Gangster
    My 580 watt hiper died not long after my antec 480 watt then there was the 500watt ocz which cr"ped itse;f after a few months and I'm now running my rig on a 400 watt qtec lmao and no probs with the qtec, this one most hated psu has outlasted all the fancy expensive psus i've ever bought.
    :rolleyes:
    So I wouldn't sweat it to much, if a 400 watt qtec can power an x1900 xt, 5 hd's, 3 pci cards, all usb ports plugged in, opteron at 2.55v, ram at 3.2v,dvd, cdrw and not have a prob then you should be fine.
  7. booyaka
    Capodecina
    minimum spec for the x1900xt is usually 450W but give it a try and see what happens if, crashing etc then lack of power would be the first place to start!
  8. sugoi
    Gangster
    i recommend at least 500W with good 12V rails... i recently bought a X1900XT and a Seasonic S12 600W PSU, my Hiper 580W PSU recently wore out, but that was for different reasons.. and if you are going to crossfire i really think you should go for a more powerful PSU than the one you mentioned... Tagan, Seasonic and Enermax are good to go into. The Enermax Liberty 500W might be better, i personally would go for one a bit more powerful.
