1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
X1900XT-X and Tomb Raider Legend
Discussion in 'Graphics Cards' started by toucam, 17 May 2006.
  1. toucam
    Hitman
    My spec:
    Connect3D X1900XT-X, Opteron 170, 2GB Memory, official CAT 6.3.
    When I turned "next generation" option on (1280x1024, max in-game option AA) , I noticed a massive reduce in FPS. Is there something wrong with my set up or even X1900XT-X can't cope with eye-candy in TBL.
  2. Calum
    Gangster
    Is your opty 170 running @ stock? It could be holding the gpu back
  3. LoadsaMoney
    Caporegime
    Have you patched the game, its supposed to help as unpatched nothing can run it in next gen mode. :)
  4. chris06
    Gangster
    have you got the patch for the game? its supposed to improve the performance on better systems!
    weather it does is another matter tho! :)
    Edit: too late again :(
  5. JustinB
    Gangster
    Yes it does, slightly i reinstalled last night and tired maxed w/ next gen and it didnt run very well without the patch.
  6. toucam
    Hitman
    Yes, it does work. Not by a huge margin but it's now quite playable. Many thanks for your suggestion.
