1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Xbox 360 hard drive
Discussion in 'Console Games & Hardware' started by clone, 8 Jun 2006.
  1. clone
    Got my daughter the world cup 360 core pack yesterday for her birthday,my question is if i buy a hard drive for it do i need anything else to fit it to the xbox.
    Also what`s the going rate for a secondhand HD.
  2. Yewen
    Capodecina
  3. wedgie
    Sgarrista
    Can't see there being a huge number of second hand hard drives available for the 360
  4. Velocity
    Wise Guy
    Nope it will just click on.
    Personally I wouldn't get a second hand hard disk.
    I don't think you can even format them?
  5. clone
    Ok thank`s :)
  6. Nismo
    Capodecina
    Yes you can, via the memory section in the system blade.
  7. Velocity
    Wise Guy
    Ahh yess. I always forget about that system blade :p
  8. Ian
    Hitman
    if you format, does that give you the full 20gig?
  9. Nismo
    Capodecina
    No, you still 'lose' the reserved space that gets allocated to the system bit and bobs.
    The max a user gets to play around with is 13 -14 gig.
  10. McDaniel
    Capodecina
    you also loose Hexic if your format.
  11. Anders0n
    Then you just ring up MS and they give you a code to download it for free. ;)
  12. McDaniel
    Capodecina
    sweet :)
