1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
XFX GeForce 6800 and 1280x1050
Discussion in 'Graphics Cards' started by Gazza, 25 Mar 2006.
  1. Gazza
    Hi
    Please can anyone tel me if the XFX GeForce 6800 supports 1280x1050 Resolution on a Digital DVI output?
    Thanks
    Gary
  2. sunlitsix
    Capodecina
    yes it will do
  3. Gazza
    Hi
    Thanks for your reply, it just that someone told me 1600 x 1200 was the nearest all Geforece 6800's get to 1680x1050.(widescreen 20”tft)
    Do you know if all makes of Geforce 6800's will do 1280x1050?
    Thanks, Just need to make sure before I order.
    Gazza
  4. sunlitsix
    Capodecina
    well if it doesnt support it natively then you can add custom resolutions and refresh rates anyway :)
  5. Gazza
    Cheers
    Gazza
  6. Curio
    Sgarrista
    Also, make sure you try unlocking the card - my XFX 6800 fully unlocked to 16/6 and also overclocks nicely with stock cooling. Superb value for money :)
