1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Xonar HDAV1.3 Slim - TMT Installed but not working
Discussion in 'Sound City' started by dlthorpe, 16 Sep 2009.
  1. dlthorpe
    Gangster
    Hi All,
    Just got this card and installed it all absolutely fine. Audio coming out of it ok and sounds good.
    I wasnt sure if i had to install the TMT that bundles with it though so i first tried to play a BluRay from my Corel WinDVD 9. That loads ok but the picture stutters like mad, and the screen has taring flicking on and off randomly - as if the picture / data isnt being sent out of my HTPC fast enough.
    I then tried to install TMT which also completed ok, but when trying to load it absolutely nothing happens. I can see a process in task manager appear for it (forget the name and im at work now), and its there for about a minute before it disappears.
    Not sure what to do next. Do you have to use the bundled TMT? Is that why my WinDVD9 didnt work? Any ideas?
    Thanks all,
    D.
  2. bledd
    Don
    check asus for updates
  3. AbsenceJam
    Mobster
    For HDMI sound you need to sue the bundled version of TMT yes. But other players should still work.
  4. dlthorpe
    Gangster
    If you mean the task manager icon and "check for updates" option then ive done that and its all up to date. That obviously only checks the Xonar software though and not TMT. TMT isnt asus is it?
  5. dlthorpe
    Gangster
    I already do get HDMI sound out absolutely fine from windows, MediaPortal, and WinDVD (although this one stutters). So its going from my mobo HDMI (out) to the HDMI (IN) on the Xonar, and then from the Xonar HDMI (out) to my amp.
    Sound works a treat except for in WinDVD9 - which i was going to stop using for the bundled TMT.
  6. AbsenceJam
    Mobster
    I meant for the proper bitstreaming or non-downsampled sound which is the point of the Xonar.
  7. dlthorpe
    Gangster
    Ahh cool. So to get the DTS-MA and TrueHD working properly use TMT.
    Id love to if only it loaded ok. Will play more tonight but thought id touch base here and see if anyone knew what it was.
    thanks for your help.
  8. Dangerous Dave
    Mobster
    Assuming you are using the drivers from the disk or Asus web page version 17.71, uninstall the current drivers and install the new drivers 17.73
    ftp://ftp.asus.com.tw/pub/ASUS/Audi...CI_HDAVslim_090617_8_17_73Vista3264_RC_01.rar
    If you are using TMT2 that came with the card then uninstall this and use the new TMT3 for the HDAV slim.
    ftp://ftp.asus.com.tw/pub/ASUS/Audio_Card/Xonar_HDAV1.3/TMT3_ASUS_Xonar_v3_0_13_136_20090720.zip
    I have this combo and it works fine. I suspect you are having problems as the 17.71 Asus drivers need the asus vista game patch installed along side it to prevent issues runnung various applications the new 17.73 drivers from the FTP site do not have this issue.
  9. dlthorpe
    Gangster
    Thanks Dave ill give it a go tonight. Do you happen to use Media Portal?
  10. james.miller
    Capodecina
    64bit OS by any chance?
  11. Dangerous Dave
    Mobster
    I use Media Browser with Windows Media Centre although I don't have ripped blu-rays only dvds. Now 1.5tb drives are cheap I may start to rip all my blu-ray/hd-dvds
    Mines runs fine in 64 bit Vista ?
  12. dlthorpe
    Gangster
    Yeh i am on 64bit OS.
    Dave: You should use media portal, its awesome. I have lotsof movies in mkv format which i link into it, as well as loads of TV series.
    This card tho is for my BluRay discs which im not really bothered about ripping, i just want to get the quality audio for them to be sent to my amp. About to try your post above now.
  13. Dangerous Dave
    Mobster
    I have tried Media Portal I prefer Media Browser running the vanilla theme.
  14. dlthorpe
    Gangster
    Ill check it out then, never heard of it :)
  15. james.miller
    Capodecina
    total media theatre? thats a suprise, since they dont support 64bit and it doesnt work for just about everybody else :p
  16. Dangerous Dave
    Mobster
    That would be incorrect I have been running TMT 3 in 64 bit Vista since it was released !
    The first release of TMT 2 didn't support 64 bit however it was resolved with an update TMT 3 has supported 64 bit since it was released.
  17. dlthorpe
    Gangster
    thanks dave your a fracking legend. done both and irobot straight away shows the DTS:MA on my amp which is the first ever. historic moment!
    whats next :)
    actually do you or anyone know how to set TMT to play in 24p if TMT even has anything to do with it? MediaPortal sets it fine for my mkvs. not sure if i have to do something similar.
  18. Dangerous Dave
    Mobster
    TMT just does what ever setting you graphic card is set to, mines runs fine with it set at 1080p/24.
  19. bledd
    Don
    I didn't mean the inbuilt updater, I never trust them
    I meant check the asus download page :)
  20. Dangerous Dave
    Mobster
    They are a little slow at moving the new updates to the drivers webpage you are better using the Asus FTP site as this gets the files first.
