1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
xp install, ethernet problem
Discussion in 'Windows & Other Software' started by Naff8000, 15 Oct 2009.
  1. Naff8000
    Wise Guy
    I've installed all types of Realtek ethernet drivers and all the ones on the Gigabyte site, still the ethernet does not work...
    Is there something I need off windows update or something? Since all I've done is slipstream SP2 onto an SP1 xp cd, no other windows updates.
    Thanks
  2. theheyes
    Sgarrista
    Just sounds like you haven't got the correct driver yet. What model motherboard is it?
  3. Naff8000
    Wise Guy
  4. mjd
    Wise Guy
    Is it showing as a unknown device in device manager?
  5. Naff8000
    Wise Guy
    No it says the driver is working
  6. mjd
    Wise Guy
    Can you ping the loopback address?
  7. Naff8000
    Wise Guy
    oops sec
  8. Naff8000
    Wise Guy
    C:\Documents and Settings\Ben>ping 127.0.0.1
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
    Ping statistics for 127.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
  9. mjd
    Wise Guy
    Well its certainly functioning on the face of it.
    How are your IPs assigned?
  10. Naff8000
    Wise Guy
    Windows IP Configuration
    Ethernet adapter Local Area Connection
    Connection-specific DNS Suffix . :
    Autoconfiguration IP Address. . . : 169.254.139.44
    Subnet Mask . . . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . . . :
  11. mjd
    Wise Guy
    That explains that then :)
    The card itself seems to be OK. You just dont seem to be picking up an IP address.
    I'm guessing you have a DHCP server running on your router and have it issuing a sufficient number of addresses etc....?
    Are you posting from another machine? Could you run an ipconfig on that and post back?
  12. Naff8000
    Wise Guy
    I dont think this is a router. Im with Virgin media, but using the modem for it that was here when I moved in. It's only got one ethernet output, which works fine on this laptop.
    Very strange ipconfig on here though :)
    Microsoft Windows [Version 6.0.6002]
    Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    C:\Users\Ben>ipconfig
    Wireless LAN adapter Wireless Network Connection:
    Media State . . . . . . . . . . . : Media disconnected
    Ethernet adapter Local Area Connection:
    Link-local IPv6 Address . . . . . : fe80::f127:b05:df87:f191%10
    IPv4 Address. . . . . . . . . . . : 77.100.101.146
    Subnet Mask . . . . . . . . . . . : 255.255.254.0
    Default Gateway . . . . . . . . . : 77.100.100.1
    Tunnel adapter Local Area Connection* 6:
    Tunnel adapter Local Area Connection* 11:
    Tunnel adapter Local Area Connection* 21:
    Tunnel adapter Local Area Connection* 22:
    Tunnel adapter Local Area Connection* 24:
    Tunnel adapter Local Area Connection* 25:
    Tunnel adapter Local Area Connection* 26:
    C:\Users\Ben>
  13. mjd
    Wise Guy
  14. Naff8000
    Wise Guy
    Ah I figured it'd be plug and play like this laptop. Excellent thanks a lot for your help, I'll give this a try.
  15. Amnesia
    Sgarrista
    have u tried powering the modem off(keep connected to ur computer) then switching it back on.
    that usually does the trick
