I'm about to upgrade my system from a Phenom ii 955 to an Intel system and looking for a recommendation for a good z77 board,
Also not sure if socket 1155 is the one to go for, or if I should be going for a x79/2011 board instead.
I mainly want something reliable with a good easy to use bios that will OC well, crossfire&SLI support would be a plus as well -
Budget is about £175 (give or take a bit)
Not sure if the z77 Sabretooth is worth the extra 70 quid compared to the Asrock extreme 4 - would appreciate any advice/recommendations on this as I haven't built an Intel system since the lga775 socket days.
