Fully-Modular Premium Power Supplies: PHANTEKS 80 PLUS GOLD AMP Series!
 Fully modular premium power supplies: PHANTEKS AMP Series with 80 PLUS GOLD-Certification
Up until now, PHANTEKS has primarily focused on enthusiasts in the PC power supply market, but now the manufacturer is dedicating its AMP series, jointly developed with Seasonic, to consumers who want to enjoy the benefits of a high-quality premium PSUs in a lower price class. The high-performance PHANTEKS AMP series features fully modular cable management, thanks to the high-efficiency 80 PLUS GOLD certification, as well as a semi-passive operating mode. In addition, all AMP-series PSUs are fully compatible with PHANTEKS Revolt Pro power supplies and come with a full 10 year manufacturer's warranty – demonstrating beyond all doubt the confidence in the quality and workmanship that goes into their products!
The PHANTEKS AMP Power Supplies in the OcUK Shop
The PHANTEKS AMP-Series Power Supplies at a Glance:
PHANTEKS AMP Series with 80 PLUS GOLD Certification
  • High efficiency with 80 PLUS Gold Certification
  • Fully modular for a tidier gaming PC
  • 550 Watt, 650 Watt or 750 Watt performance
  • 12 Volt single rail with 45 Ampere, 54 Ampere & 62 Ampere
  • Gold-plated contacts for improved resistance
  • 120 Millimeter fan with durable fluid-dynamic bearings
  • Semi-passive cooling mode (switchable)
  • Multiple 6-Pin- and 8-Pin connectors for multi-GPU setups
  • Impressive dimensions at just 140 mm
  • Full Revolt Pro Link support
  • Extensive safety features: OPP, OVP, SCP, OCP, OTP
  • 10 Year manufacturer guarantee
Max Performance for Gaming PCs & Fully Modular
The three models of the PHANTEKS AMP series offer 550 Watt, 650 Watt or 750 Watt performance to ensure plenty of power for current and future high-end gaming PCs. Above all, the strong 12V rail is fully capable of supplying even the fastest graphics cards and processors with power. The completely modular design helps create a clean interior, while also ensuring air flow within your gaming PC is optimised. In addition to one 24-pin and two 4+4-pin cables, each PHANTEKS AMP power supply provides four 6+2-pin PCIe connectors as well as eight SATA and three 4-pin Molex connectors.
Semi-Passive Cooling & 10 Year Manufacturer’s Guarantee
 Switchable Hybrid-Mode for Optimal Cooling
Thanks to the Revolt Pro Link, AMP Series power supplies can be connected to a PHANTEKS Revolt Pro power supply to increase overall performance or provide redundant power. Cases like the PHANTEKS Enthoo Luxe 2 offer space for two power supplies. A quiet, automatically controlled 120 mm fan with a light fluid dynamic bearing and hybrid mode that can be switched off helps to ensure optimum cooling while producing a minimum of noise. The high quality of the AMP power supplies with their Japanese 105°C capacitors and extensive electrical protection is reflected in the exceptionally long manufacturer warranty of ten years.
Related products
Phanteks AMP 750W 80 Plus Gold Modular Power Supply
Powerful 750 Watt power supply, High efficiency with 80 PLUS Gold certification, Powerful single rail with 62A, Modular cable management with flat cables, Certified for Revolt Pro, 10 Year Warranty
See details
Add to wishlist Remove from wishlist
Compare
10+ In stock
£106.99
Phanteks AMP 650W 80 Plus Gold Modular Power Supply
Powerful 650 Watt power supply, High efficiency with 80 PLUS Gold certification, Powerful single rail with 54 A, Modular cable management with flat cables, Certified for Revolt Pro, 10 Year Warranty
See details
Compare
20+ In stock
£96.95
Phanteks AMP 550W 80 Plus Gold Modular Power Supply
Powerful 550 Watt power supply, High efficiency with 80 PLUS Gold certification, Powerful single rail with 45A, Modular cable management with flat cabling, Certified for Revolt Pro, 10 Year Warranty
See details
Compare
20+ In stock
£86.99
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
Place an order before stock is available and book your place in the queue. You will be charged at the time of ordering.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
