Kolink – The affordable solution to cases and power supplies!
We are proud to announce Kolink, a new brand that offers an affordable solution to gaming and business cases, packed full of premium features and finished with a professional and elegant design, along with 80 Plus Bronze certified power supplies, with an aggressive price point.
The Kolink line-up of products include nine cases, three power supply units, and eight barebones systems. The Kolink products are rich in features, but also are competitively priced.
The full range of cases are the Victory Micro-ATX Gaming Case, Aviator Midi Tower Gaming Case, Satellite Micro-ATX Cube Case, Octagon Midi Tower Gaming Case, KLM-001 Micro-ATX Case, Deathclaw ATX Gaming Case, and the KLA-001 Midi Tower Case.
The Aviator Midi Tower Gaming Case comes in a various range of colours, from black, white and gun metal grey. With its aggressive gaming design, the Kolink Aviator is an excellent example of a gaming case that is packed full of features without the hefty price tag. The Kolink Aviator comes with a premium matte finish, and 3 pre-installed fans, 2 of which are Blue LED. The Aviator comes with support for up to 370mm VGA cards, 170mm CPU Coolers and 240mm Radiators on the top or front panel. Furthermore, the Aviator comes with 2 x USB3.0 ports at standard, a TF/SD Card Reader and a fan controller for excellent user interface options.
The Octagon Midi Tower Gaming Case is an imposing gaming case with an impressive set of features for the price. The Octagon comes equipped with 2 front 120mm Blue LED fans and a rear 120mm fan for good airflow out of the box. The internal structure is spacious and offers support for up to 380mm VGA, 160mm coolers, and space for 240mm radiators on the top and front. Furthermore, the Octagon comes with an attractive triangular side window to show off your build in style.
The Deathclaw ATX Gaming Case destroys the opposition with a combination of features and looks. It comes pre-installed with 3 fans, 2 of which are Blue LED, 1 x USB3.0 port on the front panel, an L shaped side window to show off your components and even supports up to 400mm VGA cards.
The full range of PSUs are the KL-400 400W '80 Plus Bronze' Power Supply, KL-500 500W '80 Plus Bronze' Power Supply and the KL-600 600W '80 Plus Bronze' Power Supply. Although these power supply units are affordable, they are also fully ’80 Plus Bronze’ certified, and meet the EU regulation for efficiency of all power supplies sold in the European Union.
Related products
Kolink Aviator Midi Tower Gaming Case - Gunmetal
With it's aggressive gaming design, the Kolink Aviator is an excellent example of a gaming case that is packed full...
See details Add to wishlist Remove from wishlist
Compare
12 In stock
£49.99
Kolink Aviator Midi Tower Gaming Case - Black
Compare
35 In stock
£49.99
(1)
Kolink Aviator Midi Tower Gaming Case - White
See details
Compare
(2)
Kolink Octagon Midi Tower Gaming Case - Black
The Kolink Octagon represents outstanding value for money and is a great choice for anyone looking for a great...
See details
Compare
Kolink KL-600 600W '80 Plus Bronze' Power Supply
The Kolink KL series are 80 Plus Bronze certified power supply units aimed at the budget system build, offering...
See details
Compare
(2)
Kolink KL-500 500W '80 Plus Bronze' Power Supply
See details
Compare
Kolink Deathclaw Midi Tower Gaming Case - Black
Prowling the wasteland of the budget computer case market, the Kolink Deathclaw destroys the opposition with a...
See details
Compare
Kolink Satellite Micro-ATX Cube Case - Black
The Kolink Satellite is a cube style chassis with impressive amounts of component support, including up to 280mm VGA,...
Compare
50+ In stock
£36.95
(4)
Kolink KL-400 400W '80 Plus Bronze' Power Supply
See details
Compare
Kolink KLM-001 Micro-ATX Case - Black
The Kolink KLM-001 is a budget focussed Micro-ATX chassis aimed at business and home office solutions.
See details
Compare
(2)
Kolink Victory Micro-ATX Gaming Case - Black
The Kolink Victory is a small tower packed full of features and would be a great case for a compact gaming build.
See details
Compare
(1)
Kolink 75-in-1 6-Port 3.5" Card Reader with USB - Black
This versatile multi-format card reader from Kolink has six slots for the integration of different card formats, e.g....
See details
Compare
OcUK Value Kolink 2.5" to 3.5" SSD or HDD Adaptor plate with screws and rubber mounts
3.5" Bay Adaptor to 2.5" SSD or HDD. Comes with Screws and Rubber Mounts included
See details
Compare
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
