Lian Li LANCOOL II with Digitally Addressable RGB-LED Lighting & Tempered Glass Doors
Lian Li LANCOOL II with digitally addressable RGB-LED lighting & Tempered Glass Side Doors
The LANCOOL II from Lian Li represents the second addition to their widely praised and sought after LANCOOL series. The Midi-Tower offers space for E-ATX motherboards up to 280 mm wide and, thanks to its large magnetic side windows, will afford users a stunning view of their high-end gaming hardware. Thanks to the digitally addressable lighting which is controlled via the I/O panel and the spacious design of the case, this is the perfect option for those planning on installing radiators. This picture of perfection when it comes to all things cooling related is available to pre-order right now at OCUK!
The Features of the Lian Li LANCOOL II at a Glance:
  • Premium Midi-Tower for motherboards up to E-ATX
  • Integrated, digitally addressable RGB-LED lighting (5V, 3-Pin)
  • Tempered Glass side doors with magnetic locking
  • Large mesh surfaces for excellent airflow
  • Space for graphics card to 38.4 cm long, CPU- coolers up to 17.6 cm
  • Power supplies up to 21 cm long supported
  • 1x 360/280 mm & 1x 240 mm radiators compatible (front & roof)
  • Includes magnetic dust filters
  • Drives: 2x 2.5" (motherboard tray), 2x 2.5" (right cover), 3x 3.5/2.5" (drive cage)
  • Includes three 120 mm fans, up to eight fans compatible
LANCOOL II: Midi-Tower for Air- and Water Cooling
With the LANCOOL II, the case design specialists at Lian Li have succeeded in creating a modern Midi-Tower distinguished by its stylish design,excellent cooling and innovative features. The case is based upon a robust steel design with a fully removable RGB-lit front cover alongside steel and tempered glass side doors that swing out. The interior offers more than enough space for dual- and triple radiators, multiple drives and powerful gaming hardware.
The all-black interior offers a huge amount of space for high-performance hardware, including for example E-ATX motherboards up to a width of 280 mm and high-performance gaming graphics cards up to 384 mm long. When it comes to CPU coolers, users have up to 176 mm of height to play with. ATX form factor power supplies may be up to 210 mm long. The reverse of the motherboard tray also supports two 2.5" SSDs on individual drive holders. The right cover's interior can hold two further 2.5" drives. Underneath the PSU shroud of the LANCOOL II, users will be impressed to know that three 3.5"- or 2.5" drives will also fit comfortably.
Stylish, Functional Design & Plenty of Space for Components
Those who prefer to opt for class air cooling will find this case a joy to work with, that's because the LANCOOL II offers an array of options when it comes to installing up to an impressive total of eight fans. Three 120 mm fans come installed by default in this Midi-Tower case. Lian Li went to great lengths to make this case absolutely perfect for the installation of AiO- and custom water cooling setups, what this means is that the front supports the mounting and installation of a 360 mm radiator or a 280 mm dual-style radiator atop an adjustable and removable bracket. The roof on the other hand reserves space for an impressively large 240 mm radiator. Both locations include pre-installed magnetic dust filters to maximise cooling and minimise the ingress of dust.
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
