Lian Li Presents its Alpha Case with Tempered Glass and Bora RGB Fans
Picking up on currrent trends like tempered glass and colorful RGB lighting Lian Li introduces new quality case and fan series. The spacious Alpha cases have plenty of room for hardware and eye-catching water cooling solutions. The mid-towers Alpha 330 and Alpha 550 remain affordable through the use of SECC steel. The basic structure of both cases is almost identical, differing only in minor details, dimensions and outfit. The front and side panels are made entirely of tempered glass elements and provide an unhindered insight into its interior. Both are available in two colour variants. The Alpha series reflects the typical care Lian Li takes in skillfully implementing sophisticated detail solutions and high processing quality. The same goes for the brand new fan series Bora.
Lots of Tempered Glass and Exemplary Cable Management for an All-Round Tidied up Appearance
With the Alpha case series and the Bora RGB fans, Lian Li introduces three new products that pick up on current trends with tempered glass and addressable RGB lighting. These features are skillfully implemented by Lian Li with its renowned focus on thoughtful detail solutions and high processing quality. The Alpha cases are very spacious mid-towers that leave a lot of room for extensive water cooling loops. They remain affordable due to the use of SECC steel and are available in two colour variants. The basic design of the 330 and 550 series are identical in construction and essentially differ only in their outfit and external dimensions.
The front and side panels are made entirely of tempered glass elements and provide extensive insight into the interior. In addition the 550-cases come with a tempered glass element in the lid, as well as the new Bora fans and an addressable RGB-LED-strip. For a tidy look, the tempered glass panel on the right is partially coated black to hide the PSU and cables can be hidden by two large covers on the mainboard tray. The cases also allow for the vertical mounting of two graphic cards. Beyond that they also have many mounting options for radiators and expansion tanks for custom cooling loops. Even without special case modding skills, anyone can present their hardware in these unique cases. The design possibilities are almost unlimited due to the numerous mounting options for hardware and cooling components.
The Features of the Lian Li Alpha 330 Midi-Towers: Lian Li Alpha 330X Lian Li Alpha 330W
  • Entry-level case designed for mainboards up to E-ATX
  • Front and side panels made of 4 mm thick tempered glass
  • Extensive cable management and smart detail solutions
  • I/O-Panel with 2x USB 3.0 / 1x USB 3.1 Type-C and HD-Audio In/Out
  • Support for two radiators in 360 and 420 mm formats
  • Vibration absorbing 4x 3.5"/2.5" and 4x 2.5" storage slots
  • Pre-installed 1x 120 mm fan, fits a total of 7
  • Supports graphics card length of 400mm and CPU Cooler height of 170mm
The Features of the Lian Li Alpha 550 Midi-Towers: Lian Li Alpha 550XLian Li Alpha 550W
  • Designer case made for motherboards up to E-ATX
  • Front, side panels and lid made of 4 mm thick tempered glass
  • I/O-Panel mit 2x USB 3.0 / 1x USB 3.1 Typ-C and HD-Audio In/Out
  • 3x 120 mm RGB Fan and RGB LED strip including remote control
>>> Pre-Order the Alpha Cases and Bora Fans at Overclockers UK! <<<
(klick here)
Bora 120 mm Fan with Addressable RGB LEDs and Remote Control
Lian Li Bora The Alpha 550 Case is equipped with three models of the new Bora fan, which are also available separately in different colours and sets. Due to its double ball bearings it runs particularly smoothly and achieves higher effective speeds at the same energy consumption, which reflects in convincing performance values of 57.2 cfm and 1.9 mm H2O static pressure. Thanks to its modular design consisting of a fan wheel and hub with dispersion ring and two aluminum frame covers, the fan is particularly easy to clean and has a custom finish. The actual optical highlight of the Boras, however, is their lighting with 16 individually addressable RGB LEDs. With the included RGB controller, PWM hub and remote control, you can configure more than 300 dynamic lighting effects in the RGB color space.
Related products
Lian-Li Alpha 330X Midi Tower Tempered Glass Case - Black
The Alpha 330X housing is a particularly affordable midi tower from the renowned manufacturer Lian Li equipped with...
See details Add to wishlist Remove from wishlist
Compare
10+ In stock
£104.99
Lian-Li Alpha 330W Midi Tower Tempered Glass Case - White
The Alpha 330W housing is a particularly affordable midi tower from the renowned manufacturer Lian Li which is...
Compare
7 In stock
£104.99
Lian-Li Alpha 550X Midi Tower RGB Tempered Glass Case - Black
The Alpha 550 housing is a midi tower with a particularly good price/performance ratio from the renowned manufacturer...
Compare
10+ In stock
£154.99
Lian-Li Alpha 550W Midi Tower RGB Tempered Glass Case - White
The Alpha 550W housing is a midi tower with a particularly good price/performance ratio from the renowned...
Compare
Out of stock
£154.99
Lian-Li Lian Li BORA RGB PWM 120mm Fan with Remote Fan Controller...
3 x PWM-Fan with Aluminum Frame and Addressable RGB-LEDs, 800 - 1900 rpm, 57.2 CFM Max Airflow, 1.9 mm Max Static...
Compare
Lian Li BORA RGB PWM 120mm Fan with Remote Fan Controller Triple Pack - Black
12 In stock
£56.99
(1)
Compare
Lian Li BORA RGB PWM 120mm Fan with Remote Fan Controller Triple Pack - Silver
9 In stock
£56.99
Compare
Lian Li BORA RGB PWM 120mm Fan with Remote Fan Controller - Black
7 In stock
£25.99
Compare
Lian Li BORA RGB PWM 120mm Fan with Remote Fan Controller - Silver
6 In stock
£25.99
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
