PHANTEKS Glacier Gigabyte C621 Aorus Xtreme Kit & C360 Water Cooler
PHANTEKS is expanding their water cooling range with the addition of three new Glacier products. The Gigabyte C621 Aorus Xtreme Kit, and the C360i and C360a water blocks. As with all the products in the Glacier series, the blocks are manufactured from the highest quality materials and represent an enviably high standard of cooling performance. The water blocks consist of nickel-plated copper and come with an acrylic cover which, in combination with the integrated RGB-LED LEDs, make for a remarkably attractive piece of specialist cooling gear.
PHANTEKS Glacier Gigabyte C621 Aorus Xtreme Water Cooler Kit
The new C621 Aorus Xtreme motherboard from Gigabyte provides 32 high-performance VRM phases and supports Intel’s newest flagship processor in the form of the W-3175X. The PHANTEKS Glacier Gigabyte C621 Aorus Xtreme Kit consists of a water cooling kit designed from the ground up for this precise motherboard. In addition to a block for the processor, it also includes a full-cover block for the VRMs as well – thus providing superb cooling for the majority of the board. Moreover, the design is unquestionably outstanding when it comes to looks as well.
  • Water cooler for the LGA 3647 Narrow-P high-end CPUs from Intel
  • Includes cooling block for VRMs on the Gigabyte AORUS C621 Xtreme
  • Nickel-plated copper block + transparent acrylic cover
  • Premium craftsmanship and elegant design
  • Covers the entire IHS and VRMs for optimal cooling results
  • Integrated digitally addressable RGB-LED lighting
PHANTEKS Glacier C360i & C360a Water Cooler
The new Glacier C360 water blocks are compatible with current Intel- and AMD sockets and are responsible for cooling the CPU. In order to offer the acrylic glass cover some additional customisation options, PHANTEKS includes two additional covers in chrome and black. With a nickel-plated copper base plate and 0.4 mm-wide and 4 mm tall fins, the C360 water blocks make for a grandiose centrepiece to your gaming PC. Viton O-rings connect the base plate with the cover. These ensure excellent thermal- and chemical resistance, meaning that users can enjoy peace of mind as the block maintains peak performance over time.
  • Extremely stylish design with RGB-LEDs
  • Nickel-plated copper cooler with special fin design
  • Swappable covers in black or chrome
  • O-Ring seals made from high-resistance Viton
  • Mounting kits for current Intel- and AMD sockets
  • Includes backplate for stable mounting
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
Place an order before stock is available and book your place in the queue. You will be charged at the time of ordering.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
