Phanteks Glacier Water-Cooling Fittings - Designed for Performance!
Phanteks is expanding their water-cooling range and has equipped their Glacier series with additional fittings for hard-tubes and universal connectors. Made from brass and created using CNC machines, these high-precision fittings are available in various types and angles, furthermore they come in two premium colours (black or chrome). Equipped with a high-flow design, the fittings offer superb performance for custom water-cooling setups and are primarily targeted at the Glacier waterblocks from Phanteks.
>>> To the Phanteks Glacier Fittings in the Overclockers Shop! <<<
The Key Features of the Phanteks Glacier Fittings at a Glance:
  • Fittings & adapter for water-cooling
  • Impressive performance thanks to the efficient high-flow design
  • High reliability and precision manufacturing with zero tolerances
  • Premium design - available in black or chrome
  • Easy grip surface to make installation a breeze
  • CNC machined from solid brass
  • Perfect compatibility with Phanteks water-cooling components
  • Resistant against high temperatures & aggressive liquid coolants
Manufactured to Optimise Water-Cooling Performance!
The Phanteks Glacier Fittings have been designed so as to ensure compatibility with all available Phanteks water-cooling components while coordinating with each other aesthetically. To this end the fittings have been manufactured in the highest quality materials to meet the demanding requirements of Phanteks. The Glacier Fittings have been CNC-machined from solid brass to provide an ingenious high-flow design capable of meeting the requirements for extreme water-cooling.
The fittings are available in a striking black as well as shining chrome. They are resistant against extreme temperatures and aggressive liquid coolants, meaning that their lifespan is dramatically increased. The fittings for hard tubes are furthermore designed for pipes with an outer diameter of 12 and 16 mm and utilise a high-end Viton O-ring to ensure a superb watertight fit for the cooling loop.
Related products
Phanteks M-F Rotary Fitting G1/4 - Chrome
Multi Link adapter, Extender, Chrome, 5 Year Warranty
See details Add to wishlist Remove from wishlist
Compare
1 In stock
£8.99
Phanteks M-F Rotary Fitting G1/4 - Black
Multi Link adapter, Extender, Black, 5 Year Warranty
Compare
1 In stock
£8.99
Phanteks F-F Adapter G1/4 - Chrome
Multi link adapter, Extender, Chrome, 5 Year Warranty
Compare
3 In stock
£4.99
Phanteks F-F Adapter G1/4 - Black
Multi link adapter, Extender, Black, 5 Year Warranty
Compare
Out of stock
£4.99
Phanteks 16mm Hard Tube Adapter 90° - Chrome
16mm Hard Tube Fitting, 90 Degree, Black, 5 Year Warranty
Compare
15 In stock
£17.99
Phanteks 16mm Hard Tube Adapter 90° - Black
16mm Hard Tube Fitting, 90 Degree, Chrome, 5 Year Warranty
Compare
22 In stock
£17.99
Phanteks 16mm Hard Tube Adapter 45° - Chrome
16mm Hard Tube Fitting, 45 Degree, Chrome, 5 Year Warranty
Compare
11 In stock
£15.95
Phanteks 16mm Hard Tube Adapter 45° - Black
16mm Hard Tube Fitting, 45 Degree, Black, 5 Year Warranty
Compare
3 In stock
£15.95
Phanteks 16mm Hard Tube Rotary Fitting 90° G1/4 - Chrome
16mm Hard Tube Rotary Fitting, 90 Degree, Chrome, 5 Year Warranty
Compare
7 In stock
£17.99
Phanteks 16mm Hard Tube Rotary Fitting 90° G1/4 - Black
16mm Hard Tube Rotary Fitting, 90 Degree, Black, 5 Year Warranty
Compare
Out of stock
£17.99
Phanteks 16mm Hard Tube Rotary Fitting 45° G1/4 - Black
16mm Hard Tube Rotary Fitting, 45 Degree, Black, 5 Year Warranty
Compare
16 In stock
£17.99
Phanteks 16mm Hard Tube Rotary Fitting 45° G1/4 - Chrome
16mm Hard Tube Rotary Fitting, 45 Degree, Mirror Chrome, 5 Year Warranty
Compare
12 In stock
£17.99
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
