PHANTEKS Revolt PRO: New Power Supply with Innovative Features!
PHANTEKS Revolt PRO
PHANTEKS is proud to present the Revolt PRO, a unique contribution to the world of power supplies. Thanks to PHANTEKS' Power Combo patented Power Combo technology, two Revolt PRO power supplies can be linked together. This power supply, developed in collaboration with Seasonic, is not only fully modular, it has also received the coveted 80 PLUS Gold certification as well as unparalleled failsafe performance thanks to the redundancy that only two PSUs together can offer. The PHANTEKS Revolt PRO is available at Caseking now!
Maximum Performance
With up to 1000 Watts of power available, the PHANTEKS Revolt PRO is so powerful that overclocked systems kitted out with multiple processors or graphics cards present no obstacle to this PSU. Needless to say, connecting two of these together makes for an even more remarkable increase in performance. In essence, the arrival of the Revolt PRO from PHANTEKS represents new levels of stability and inbuilt redundancy in the consumer market that have - until now - been restricted to the server space. Power is regulated automatically between two connected power supplies in such a way that it effectively continues to supply power without missing a beat in the unlikely event that one power supply should fail.
Absolute Premium Quality
This innovative feature alone wasn't enough for PHANTEKS however. Additionally, their cutting-edge PCB design utilises cable-free connections as well as Japanese 105°C capacitors for maximum quality. The fan control is also impressive here, as the semi-passive functionality enables the fan to be switched off when under loads of less than 40 percent. As such, under low loads the PSU remains absolutely silent. The exterior of the power supply also receives the quality touches that PHANTEKS' has become known for with the use of sleeved, fully modular cables to make your system look incredibly clean and tidy while you game.
Related products
Phanteks Revolt Pro 850W 80 Plus Gold Modular Power Combo Supply
Supports dual PSU configuration, 80 Plus gold accredited, Made from high quality components and materials
See details
Add to wishlist Remove from wishlist
Compare
7 In stock
£124.99
(1)
Phanteks Revolt Pro 1000W 80 Plus Gold Modular Power Combo Supply
Supports dual PSU configuration, 80 Plus gold accredited, Made from high quality components and materials.
See details
Compare
4 In stock
£149.99
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
