Portable Premium Case from Lian Li: TU150 with Convenient Carry Handle & Max Performance!
Portable premium case from Lian Li: TU150 with convenient carry handle and premium performance!
Lian Li have a long history of making light and portable cases. The new Lian Li TU150 carries forth this tradition, offering users a stunning case complete with a fold-out carry handle. In spite of the Mini-ITX case's compact dimensions, it still offers more than enough space for long graphics cards and tall CPU coolers. The end result is an uncompromising case that has the sleek looks of a portable case and all the performance of its bigger brethren. As we have come to expect from Lian Li over the years, achieving the desired look has entailed the use of attractive brushed aluminium - now available in black or silver variants, along with a tinted tempered glass side panel.
Lian Li TU150 Mini-Tower in black or silver at OcUK
The Lian Li TU150 Mini-ITX case at a glance:
Lian Li TU150 with Carry Handle
  • Compact: 203 x 312 x 375 mm & Mini-ITX motherboards
  • Graphics cards up to 320 mm and CPU coolers with 165 mm height
  • Designed for space-saving SFX- or SFX-L power supplies
  • Case comes in brushed aluminium
  • Tinted tempered glass side panel
  • Carry handle integrated into the case for maximum portability
  • 1x 3,5"- & 1x 2,5"-drive or 2x 2,5" drives
  • Four slots for 120mm fans in front, rear and bottom
  • I/O-Panel: one USB 3.1 Type-C- and two USB 3.0-Type-A ports
Small, portable, ultra-mobile & Surprisingly Powerful Hardware
Lian Li TU150: Ultra-Portable & Powerful Hardware
The TU150 from Lian Li brings with it a variety of features in a compact Mini-ITX case, this is then combined with a convenient fold-out carrying handle integrated into the top. Despite the diminutive dimensions of the case, it is more than capable of supporting powerful gaming hardware. CPU coolers up to 16,5 cm in height are supported, along with graphics cards measuring up to 32 cm in length. Space-saving SFX- or SFX-L power supplies fit in the case, and nowadays their performance is nearly indistinguishable from full-size ATX power supplies - meaning that once again, users benefit from the best of both worlds. The I/O panel on the top includes a USB 3.1 Type C port alongside the obligatory audio ports and power/reset buttons as well as two standard USB 3.0 Type A ports.
Optimal Cooling Design and Protective Dust Filters
Lian Li TU150 with full performance & optimal cooling
The horizontal airflow design with front- and rear 120mm fan slots (fans not included) means that all your installed hardware will receive more than adequate cooling. The front of the case includes side-mounted air inlets with a tightly woven mesh, while the fan slots include removable dust filters for preventing dust ingress and easy maintenance. Additionally, two fans can be installed in the bottom of the case in order to help exhaust warm air from the graphics card. Those who prefer to opt for water cooling will be pleased to note that a 120mm radiator can be installed in the back instead of a fan.
Related products
Lian-Li PC-TU150WX Aluminium Mini-ITX Case - Black Window
Ultra-portable premium case from Lian Li, Brushed aluminium, Tempered glass side panel, Mini-ITX/DTX support, 4x 120 mm fans & 1x 120 mm rad supported, Carrying handle & 1x USB 3.1 Type C
See details
Add to wishlist Remove from wishlist
Compare
20+ In stock
£99.95
Lian-Li PC-TU150WA Aluminium Mini-ITX Case - Silver Window
See details
Compare
20+ In stock
£99.95
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
Place an order before stock is available and book your place in the queue. You will be charged at the time of ordering.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
