Raijintek Orcus RGB AiO Watercoolers - Now with Addressable RGB Lighting!
AiO Orcus RGB Watercooling from Raijintek
Update 1 – Raijintek Orcus RGB Complete AiO Available Now with Addressable RGB Lighting
Original Post – Raijintek's Orcus AiO: A New Generation of All-in-One Watercooling Solutions
Raijintek Orcus RGB Complete AiO: Available Now with Addressable RGB Lighting
After the Orcus RGB AiO's successful breakthrough onto the watercooling scene, Raijintek has expanded the series once again with the addition of new Rainbow models that include addressable RGB lighting. Control is possible thanks to the included remote control or via 5V ADD header, something which is compatible with modern motherboards from manufacturers such as ASUS, Gigabyte, MSI and ASRock. Lighting can then be controlled via your motherboard's included software.
The new Rajintek Orcus RGB Rainbow will be available with 140- or 280mm radiators and fit perfectly with highly overclocked CPUs thanks to the incredible cooling they offer. The improved pump is now even able to move up to 86- instead of 66 Litres per hour. Remarkably, the already excellent cooling performance offered by Raijintek's first-gen Orcus RGB has been taken up yet another notch.
Raijintek's Orcus AiO: New Generation AiO Watercooling
The AiO Orcus RGB from Raijintek
Premium materials and an ingenious design paired with some seriously stylish looks: The renowned manufacturer of high-end cooling solutions, Raijintek, have introduced an unusual but effective new take on AiO CPU cooling with the AiO Orcus. Raijintek has shifted the pump away from the heatsink and towards the 240mm radiator. This results in greater flexibility in terms of how the Orcus is installed. The pump offers a maximum throughput of 66 L per hour in terms of coolant passing from the copper heatsink and through the radiator. The heatsink comes with a transparent window behind which is located a small wheel that serves to indicate the flow rate. Even the coolant volume can be monitored from here. It goes without mentioning of course that the heatsink features stylish RGB lighting. To this end Raijintek also includes a controller and remote.
The Orcus AiO from Raijintek:
  • Full water cooling system with straightforward installation
  • Pre-filled and maintenance free
  • High cooling performance with 38 mm thick dual-radiator
  • RGB controller and remote is included in the bundle
  • Quiet 25 dB(A) pump with a 66 Litre/h throughput
  • Excellent compatibility with AMD and Intel sockets
Powerful Iris Rainbow Fan from Raijintek
With its hydraulic bearings both Iris fans perform a sterling job in dissipating the heat away from the radiator, all while offering an extremely long lifespan. Spinning at up to 1800 RPM the fans provide excellent airflow totalling 71.65 m³/h while emitting just 23 dB(A). The static pressure sits at a surprisingly powerful 1.7 mm H2O. The speed of the 120 mm fans are automatically regulated by means of a single 4-pin Y-cable to a free PWM connector on the accompanying AiO controller or via a 4-pin RGB header located on the motherboard.
Raijintek IRIS 12 Rainbow RGB LED Fan:
  • 120 mm fan with PWM function
  • Optimised eleven fan-blade design
  • Spins at 1800 RPM
  • 71.65 m³/h airflow
  • Effective static pressure of 1.7 mm H2O
  • O-type LED Ring RGB lighting
  • Efficient bearings for improved durability
  • Anti-vibration pads for minimising noise
Related products
New
Raijintek Orcus RBW Addressable LED AIO Water Cooling Unit - 140mm
Addressable RGB Fans, 140m Radiator and Fan, Comaptible with Latest AMD and Intel Sockets, 2 Year Warranty
See details
Add to wishlist Remove from wishlist
Compare
Pre Order
£89.99
New
Raijintek Orcus RBW Addressable LED AIO Water Cooling Unit - 280mm
Addressable RGB Fans, 280m Radiator and 2 x 280mm Fan, Comaptible with Latest AMD and Intel Sockets, 2 Year Warranty
See details
Compare
Pre Order
£109.99
Unfortunately no comments have been given.
This is your chance
Make the first comment.
Write a comment
* Required field
Stock level indicator
Pre Order
New item that you can order before we receive stock. Orders will be shipped on a first come first served basis. If an ETA is available it will be displayed on hover.
Bought to order
Items that are bought by us when a purchase is made, this generally is for highly expensive items, items with a very slow run rate or speciality items
In stock
The item is in stock.
Due today
The item is out of stock and expected to arrive today.
ETA: XX.XX
The item is out of stock and estimated to arrive on the date provided.
Built To Order
The Item is built to order. As you change the options, the stock status will automatically update depending on your selection.
Out of stock
The item is out of stock and estimated delivery date is not known at this time.
