Looking to level up your aesthetics by vertically mounting your graphics card? Don’t have a case that supports it? Well, it’s time to check out five of our best PC cases for vertical GPU mounting.
Each of our top picks features extensive support for all the latest tech along with incredible aesthetics, meaning you’re sure to find your next great upgrade.
HAVN HS420 VGPU White Mid Tower
Meet the HAVN HS420 VGPU, the new standard of PC case. This PC case has been built utilising only the finest materials, fine-tuned specifically for vertical GPU mounting, featuring a dedicated GPU mount and fan bracket as standard. The heat-formed UniSheet panoramic glass allows for an unparalleled view of the interior of your chassis. What’s more, compatibility with up to E-ATX motherboards and GPUs 470mm long, means you can instal a range of modern-day hardware to boost your gaming and productivity. The included GPU bracket features a PCIe 5.0 riser cable for rapid connectivity. The mount seamlessly integrates within the case for a unified modern aesthetic.
Please note that the vertical GPU bracket is included.
Phanteks NV5 Black Mid Tower
Build an impressive gaming PC housed within the Phanteks NV5 Mid Tower. This sleek mid tower chassis boasts wide support for a huge range of hardware, including ASUS BTF motherboards and vertical GPU mounting (required bracket sold separately). Easily instal a GPU up to 440mm long and an E-ATX motherboard. The tempered glass panels grants a panoramic view of your components, allowing you to display them with pride. Integrated within the Phanteks NV5 is a DRGB light strip. The included controller enables you to customise the colour and effect to suit your desired aesthetic.
HYTE Y70 Blueberry Milk Mid Tower
Dreaming of a stylish all-blue gaming PC? The HYTE Y70 is the perfect choice for you, sporting a smooth blueberry colour scheme. It has a dual chamber interior that can support up to E-ATX motherboards and 422mm long GPUs. To vertically mount your graphics card, a 4-slot mount and PCIe 4.0 16x riser cable is included with this case, which will seamlessly blend into the interior of your chassis. Quality of life features such as helpful labels, reusable Velcro straps, and floating storage sleds streamline the building process, making the HYTE Y70 perfect for beginners and veterans alike.
Please note that the vertical riser cable is included.
Corsair iCUE RGB 6500X White Mid Tower
Create a show stopping PC with the Corsair iCUE RGB 6500X Mid Tower. Sporting a dual chamber interior, this case is compatible with up to E-ATX motherboards and GPUs 400m long. You can pair this case with reverse connection motherboards such as ASUS BTF and MSI Project Zero for a truly cableless clean interior. Included with this case are three pre-installed RX120mm RGB fans, connected via iCUE LINK System Hub, allowing you to customise the colour and effect to suit your style. What’s more, the 6500X supports vertical GPU mounting (required bracket sold separately).
Kolink Observatory Y Mesh ARGB Black Mid Tower
The Kolink Observatory Y Mesh features plenty of incredible aesthetics and extensive support for modern-day hardware. This mid tower case has been built utilising high-quality materials, featuring a full mesh front panel to facilitate outstanding airflow. Paired with the four pre-installed Kolink Umbra PWM fans, you’ll have everything you need to enjoy cool and whisper-quiet performance. The hinged tempered glass panel enables you to display your hardware with pride, and this case comes equipped with support for vertical GPU mounting (required bracket sold separately).
Phanteks Eclipse G400A DRGB Satin Black Mid Tower
Effortlessly stylish, the Phanteks Eclipse G400A is the perfect upgrade for those looking to vertically mount their GPU (required bracket sold separately). This chassis sports a sleek satin black finish and plenty of support for modern-day hardware, including E-ATX motherboards and 415m long graphics cards. What’s more, extensive cooling options make maintaining your components at ideal temperature easy, featuring four 140mm Phanteks M25 fans and a dedicated top radiator mount. The built-in DRGB strip down the side adds a vibrant splash of colour, which you can configure to suit the rest of your set-up.
Still Looking for the Perfect Case?
If none of these PC cases suit your aesthetic, you can browse our entire collection of vertical GPU cases and compatible brackets.
Explore Our Top PC Cases
Do You Mount Your GPU Vertically?
Do you mount your GPU vertically? If so, what PC case do you use? Share your product recs in the comments below.
