Best PC Systems for Rendering
What are the best PC systems for rendering?
Rendering and 3D rendering are intensive workloads that you can’t do on any old spec. If your hardware isn’t powerful enough, it will struggle with the software, resulting in lag and frustration. We’ve got the info you need to make sure you have the right hardware for the job.
Rendering
What is rendering? It is the process of an image being generated based on data input. Your graphics card does it every time you boot up a game, using all that spicy tech to render images in real time with smooth frame rates.
With a 3D rendering program, you can create 3D models, make visual effects, build complex designs, and so much more. You are creating something from scratch and, therefore, need some graphical and processing power behind you.
There is a range of 3D rendering software available, each offering the tools you need. Some are tailored for beginners and those still honing their skills, whereas others are more specialist and advanced. Popular programs include Blender, V-Ray, Enscape, and Lumion.
Blender Specifications
We’re going to focus on Blender. It is a free, open source program with lots of user-friendly features and a very active community. This software can be used by beginners and veterans, alike, as it provides an all-in-one platform for a range of styles.
ComponentMinimum SpecsRecommended Specs
Operating SystemWindows 8.1
64-bit
Windows 11 / 10
Processor4 cores with SSE4.2 support8 cores
Memory8GB RAM32GB RAM
Graphics2GB VRAM with OpenGL 4.38GB VRAM
Further info on GPU compatibility is available here (external link).
While it has relatively accessible specifications, certain features require more specialist hardware. This includes the option to render using your GPU rather than CPU, as this can speed up the process. What may hold back the standard GPU, here, is limited memory. However, if you use a workstation GPU instead, they feature much higher memory capacities and technology that is fine-tuned to deal with the demands of 3D rendering. If this is a feature you are looking to implement, you can find out more here (external link).
PC Systems for Rendering: What You Need
An 8-core CPU, 32GB RAM, and 8GB VRAM is all very achievable with a gaming PC. Even with a mid-range CPU and GPU from the latest Intel, AMD, and NVIDIA line-ups, you can more than meet the requirements. However, using more powerful hardware will make the process quicker and more seamless. Plus, harnessing components purpose built for creative workflows will mean your efforts are supported by specialist software and hardware.
It all depends on your requirements. The more complex the project, the more powerful the hardware you’ll need.
Rendering PC Typical Specification
Below, we have the base specifications for one of our professional RENDA PCs. This computer harnesses an Intel Core Ultra 7 265K CPU, 64GB DDR5 RAM, and an NVIDIA GeForce RTX 5070 Ti GPU, fully showcasing how the hardware we love for gaming is also primed for 3D rendering.
Specifications
ProcessorIntel Core Ultra 7 265K CPU
Ultra 9 model available
Memory64GB (2 x 32GB) DDR5 5200MHz Dual Channel RAM
Up to 96GB available
GraphicsNVIDIA GeForce RTX 5070 Ti 16GB GDDR7 Graphics Card
Alternate options available
StorageSelect multiple NVMe SSDs from a range of capacities
RENDA Creator3D Core - Intel Core Ultra 3D Design And Animation Workstation
RENDA Creator3D Core – Intel Core Ultra 3D Design And Animation Workstation
SYS-REN-00064
£3999.98 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Best PCs for Rendering
At Overclockers UK, we have a range of PC systems that are crafted for 3D rendering and more professional needs. We’re going to take a closer look at them here.
RENDA
RENDA is our range of high-performance business computers. Each system is engineered with hardware that is well suited for professional workloads such as 3D rendering, game development, and more. On top of this, there are configurable options, enabling you to scale up the PC’s performance as you need it. Take our previous example, the RENDA Creator3D Core. You can bump up the RAM capacity, increase the storage solution, and even opt for professional-grade graphics cards. And those are just the options native to the website. If you contact our dedicated team, we can explore your options in more detail.
From start to finish, we will help guide you to ensure your PC is crafted to meet your exact needs. We will select the best components for the job, use off-the-shelf solutions where needed, and provide outstanding customer service throughout the process.
RENDA is here to turbocharge your business by providing the hardware you need to optimise your workflow.
8Pack
The other option available at Overclockers UK is the 8Pack range. These are extreme, overclocked PCs that harness the latest hardware to deliver mind-blowing performance. Designed and overclocked by Ian “8Pack” Parry, these PC systems use bleeding-edge technology and bespoke solutions to create something truly phenomenal.
Their custom-built water-cooling loops keep operations whisper-quiet while providing bold aesthetics that make these PCs statement pieces as much as powerhouses.
As with the RENDA systems, there is plenty of scope for customisation. Each 8Pack PC will have a range of configurable options available, but you can also contact our Prestige Systems Advisor on 01782 940 193 to see how we can tailor these behemoths to fit your rendering needs.
Customer Support
If there is one key take away from this article, it’s that we’re here to help. Our team is dedicated to making sure you get the PC you need – whether it’s for 4K gaming or complex 3D rendering. You can contact us through the means already provided, or drop us a request through our online help desk!
Enhance Your Workflow
Your Guide to Workstation Graphics Cards
AMD Threadripper Ryzen PRO 9000 Series CPUs are Here!
Should You Finance Your Gaming PC?
What’s Your Spec?
What hardware and software are you 3D rendering on? Let us know in the comments below.
PC specs are subject to change.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
