Our CPUs are wonderful pieces of tech. At the core of every PC, the processor does exactly what it says on the box – processing all your applications at record speeds. To achieve this, a CPU consists of multiple powerful components that work in sync and communicate with each other to execute your workloads. One of which is a CPU register.
What is a CPU register, you ask? We’ve broken down everything you need to know.
What is a Register in a CPU?
Register is a type of computer memory that is directly built into the CPU. It serves as a short-term, quick memory solution, storing any data that your processor may need quickly to carry out complex tasks.
How Does a CPU Register Work?
A CPU register consists of multiple flip-flops, a type of electronic circuit that’s capable of quickly storing single bits of information, often represented in binary. Equipped with multiple flip-flops, the CPU register can store large binary values like bytes or words. What’s more, a CPU register also features control logic circuitry. This enables the register to control the flow of data and instructions within the processor and uses multiplexers to reroute data to specific locations.
Both of these work in tandem to enable the register to quickly store and process data efficiently during complex instructions or workloads. The flip-flops provide the storage capacity, while the control logic transfers the data and communicates with other components inside the CPU.
Don’t know what other components make up a processor? Our ‘anatomy of’ series takes you on a guided tour through the inside of a CPU.
The Different Sizes of CPU Registers
There are different sizes of CPU registers. The size is determined by the actual design of the processor and can impact overall performance. Most modern CPUs can include:
- 8-bit register – this register can store 8 bits (1 byte) of data and is commonly found in older CPU generations. 8-bit registers are often used for very basic applications.
- 16-bit register – capable of storing 16 bits (2 bytes) of data
- 32-bit register – this register can store 32 bits (4 bytes) of data and is widely used in processors since it is capable of handling notably larger data sizes and complex calculations.
- 64-bit register – capable of storing 64 bits (8 bytes) of data and is considered the standard that all modern-day CPUs now use. A 64-bit register often provides a serious increase in power, capable of handling multiple sets of instructions at a time and large quantities of information.
Most PCs will include either a 32 or 64-bit CPU. However, you can find larger sizes, such as 128-bit, but these are used for very specific applications, such as vector processing.
In Need of a CPU Upgrade?
Struggling with poor performance? Looking to upgrade your processor? Whatever the case, you are sure to find your next great upgrade at Overclockers UK. We stock an extensive range of the latest CPUs from both Intel and AMD, designed to suit a variety of needs and budgets.
AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor – Retail
PRO-AMD-03517
£409.99 £ 368.99
-10%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Intel Core Ultra 7 265F (Arrow Lake) Socket LGA 1851 Processor – Retail
PRO-INT-03939
£384.98
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETLearn More About Your CPU
Got a Burning Question About Your CPU?
Got a question to ask about your CPU? Leave in the comments below, and we may use it as inspiration for a future blog post!
