Have you ever stopped to admire the shadows and reflections in a game and wondered how developers make them look so real? That realism comes from ray tracing.
Ray tracing technology plays a huge role in immersing us in modern games by shaping lighting, time of day, and atmospheric effects. If you want to learn more about this exciting, revolutionary technology, we’ve got the goods below!
What Is Ray Tracing?
Ray tracing is a rendering technology that casts a light ray out from the camera’s POV, then traces its path as it interacts with different objects in-game, all feeding back to a light source.
Are the shadows of your avatar perfectly mimicking your in-game movement? That’s ray tracing. Are you able to look at in-game mirrored surfaces and see the game world reflected in vivid detail? That, too, is ray tracing! Is light bouncing off objects as it would IRL? Well, by now you can guess what’s responsible!
In a line? Ray tracing helps to make your modern games look real!
Want to know which games make the most of ray tracing? Read on for more!
How Does Ray Tracing Work?
Ray tracing can be summed up as a series of rendering algorithms. It has worked in a variety of ways since its inception, starting with huge quantities of dedicated processors that would take whole days to render scenes for movies!
However, NVIDIA changed the game in 2018 with the release of their Turing-based GPUs. Since this breakthrough, graphics cards boast advanced Ray Tracing cores and accelerators to render real-time ray tracing in your games. These cards are equipped with many functions and capabilities, such as ray casting, Bounding Volume Hierarchy (BVH), Ray-Traced Ambient Occlusions, and more.
Ray Casting Foundations
Ray casting is the foundational algorithm in the ray tracing family. The sampling of a scene starts here.
Ray casting establishes the rays from the point of view camera across each pixel on-screen. Then, this algorithm detects what they hit and what colour and lighting data can be extrapolated from those objects.
Acceleration with the Bounding Volume Hierarchy (BVH)
Creating a scene is a highly complex task. To reduce the number of calculations required for each ray, acceleration techniques are introduced to trim the fat.
BVH is one such ray tracing acceleration technique. It’s a data structure that helps the engine identify more quickly which objects a ray interacts with. Even if that object has millions of polygons, BVH shortens the processing time and gets the lighting effects rendered!
Ray-Traced Ambient Occlusion Techniques
Lighting isn’t just about focusing on the illuminated objects. It must also authentically create any subsequent shadows and determine how they play off the surrounding environment.
Ray-traced ambient occlusion is the algorithm responsible for rendering shadows in areas blocked by ambient lighting. These could be the corners of rooms or even in the folds of wrinkled skin. The level of detail it can simulate is meticulous.
Real-Time Global Illumination
Day-to-night cycles in games have never been more immersive! We have real-time global illumination to thank for that.
Global illumination used to be precomputed, monitoring how indirect light bounces and diffuses when it comes in contact with a surface. Today, it’s yet another algorithm that’s been enhanced for real-time results.
Denoising Finishing Touches
Post-processing techniques are just as essential for rendering realistic digital environments. This is where the fine-tuning comes into play.
Denoising is a further set of algorithms that scrub out blocky, grainy resolutions and unsightly discolouring. These anomalies aren’t part of the original image, and their removal results in a more photorealistic finish!
Is Path Tracing Different to Ray Tracing?
Path tracing and ray tracing shouldn’t be referenced interchangeably. They are separate technologies.
However, ray tracing is often associated with path tracing. Because they are sometimes confused for one another, it’s worth distinguishing them.
Path tracing is an enhanced form of ray tracing that tracks hundreds of thousands of rays ricocheting off objects or coming from the light source. It used to produce better results than standard ray tracing at the expense of speed, and so was reserved for long pre-rendering projects.
Today, path tracing has been developed to such a degree that its processes have sped up considerably. It’s now fit for producing real-time results in gaming, but it does require a lot more computing power and DLSS 4 support to get up and running.
What Hardware do I Need for Ray Tracing?
While fancy lighting, reflections, and shadows aren’t strictly new to gaming, they’ve never been as frequently or sharply displayed as they are today. So long as you have the right hardware, you can enjoy these immersive visuals!
Here’s a quick table highlighting the minimum hardware requirements that will enable ray tracing:
Minimum Hardware Requirements
Dedicated GPU with ray tracing hardware –
NVIDIA RTX 20 Series or higher / AMD Radeon RX 6000 Series or higher
At least 8GB RAM
Intel Core i5 CPU or equivalent
Ray tracing is quite an intensive task. Should your components not be quite up to the task, you might experience a drop in performance. So, we recommend using powerful hardware that meets the recommended gaming specifications for CPU, GPU, and RAM before enabling ray tracing.
In Need of an Upgrade?
If you want to enable ray tracing, but your PC doesn’t have the sauce yet, don’t worry! Here at Overclockers UK, we’ve got everything you need to make the upgrade!
Asus GeForce RTX 5060 LP BRK OC 8GB GDDR7 PCI-Express Graphics Card
GRA-ASU-05707
£419.99 GBP
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Asus GeForce RTX 5090 TUF Gaming OC 32GB GDDR7 PCI-Express Graphics Card
GRA-ASU-04148
£7199.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Sapphire Pulse Radeon RX 9060 XT Gaming 16GB GDDR6 PCI-Express Graphics Card
GRA-SPR-05179
£599.99 GBP
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
More Ray Tracing Content
Ray-Tracing: Five Games to Make Your PC Sweat
Horizon Forbidden West
Do You Have Ray Tracing Enabled?
Do you enjoy all the perks ray tracing affords? Or do you need to make a strategic upgrade to confidently enable it? Whatever your situation, we’d love to hear all about it in the comments!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
