Have you got a dream airflow cooling build in mind? Do you need a PC case upgrade to realise it?
As we continue our Best PC Cases series, we’re taking a closer look at the PC cases that facilitate airflow best. Let’s count ‘em down!
Lian Li Lancool 207 PC Case
While we were tempted to start the list with the Lian Li Lancool 217 INF, we opted for Lian Li Lancool 207 PC case instead. We did this for the highly porous mesh featured on the top panel, front panel, and even the side of the PSU chamber, all of which facilitate phenomenal airflow. What’s more, the four pre-installed cooling fans further regulate thermals. This includes two ARGB 140mm fans on the front of the case, which deliver an impressive 109.3CFM of airflow at a static pressure of 3.3mmH20. Meanwhile, two 120mm fans are positioned at the top of the PSU chamber and can deliver 71.1CFM of airflow thanks to their 11-blade design. As you might expect, yet more cooling hardware can be installed in this case, with the rear supporting a 120mm fan, while the top of the case has room for two 140mm or three 120mm fans as well as mounting points for a 360mm radiator.
Lian Li Lancool 207 - Black
Lian Li Lancool 207 – Black
CAS-LIA-02814
£74.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Lian Li Lancool 207 Digital - Black
Lian Li Lancool 207 Digital – Black
CAS-LIA-04526
£99.95 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Antec AX-1000 ARGB Mid-Tower Mesh Airflow Case
Not only is the Antec AX-1000 ARGB Mid-Tower Mesh Airflow Case pretty snazzy on the style front, but the sleek geometric front panel is also enhanced by the steel mesh. This bolsters the cooling performance considerably, improving heat dissipation. What’s more, this PC case has three 140mm ARGB PWM fans pre-installed at the front, with one more placed at the rear. Nine fans can be supported in total, while the front and top can also accommodate radiators up to 360mm. Plus, there’s also clearance for CPU coolers up to 185mm tall. Last, but certainly not least, this case has detachable magnetic dust filters on the top, bottom, and right side for easy cleaning. Less dust means better airflow!
NZXT H7 Flow PC Case
Proudly standing as a high airflow mid-tower PC case, the NZXT H7 Flow has mounting points for up to ten fans! Plus, this chassis has three F120Q fans pre-installed at the front. The H7 Flow also accommodates up to three radiators, with front support for a 420mm model, top support for a 360mm radiator, and the rear panel boasting mounts for a 140mm radiator. To maximise airflow around the power supply, the PSU chamber has been vertically assembled, and also features built-in hooks and Velcro straps to make bundling cables easier. Better yet, the front, top, and side panels can be removed without tools, helping you prevent the obstruction of airflow while also making cleaning simpler.
Corsair iCUE Link 9000D AIRFLOW Super-Tower PC Case
The Corsair iCUE LINK 9000RD RGB AIRFLOW Super-Tower PC Case has plenty of cooling capabilities to show off! First is the immense form factor, which offers ample breathing room for high-end components, cable routing, and airflow channels. Plus, this case features an improved, high-airflow steel front panel, which is easily removed to make cleaning your PC easier. On top of that, you can either house a whopping eighteen 120mm fans in this case or install four 200mm fans and multiple radiators up to 480mm. What’s more, you can flexibly mount fans and radiators with the InfiniRail Fan Mounting System, designed to make installation far easier compared to using fixed-fan brackets. These flexible brackets can easily be adjusted, allowing them to accommodate fans between 120mm and 200mm.
HAVN BF 360 Flow Mid-Tower PC Case
Considering it made our best PC cases of 2026 shortlist, we’d be most foolish not to mention the HAVN BF 360 Flow Mid-Tower PC Case. This high-airflow ATX mid-tower chassis innovates on cooling, featuring one HAVN H14 and two HAVN H18 fans out of the box. Airflow rate is maximised at 315.1CFM and provides full coverage to all your gaming hardware. This is thanks to the semi-open design and the front, top, and rear panels having rib pattern styling for improved ventilation, allowing the case to breathe. Plus, the HAVN BF 360 Flow boasts aerodynamic features, such as the 135° ramp that funnels cool air directly to the GPU.
HAVN BF 360 Flow Premium Mid Tower Case - Black
HAVN BF 360 Flow Premium Mid Tower Case – Black
CAS-HVN-05948
£169.99 GBP
(incl. VAT)
FREE SHIPPING
Pre order
ADD TO BASKET
HAVN BF 360 Flow Premium Mid Tower Case - White
HAVN BF 360 Flow Premium Mid Tower Case – White
CAS-HVN-05949
£169.99 GBP £ 134.99 GBP
-20.59%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
More PC Cases?
Not swayed by our cherry-picked cases? Do you have other considerations on top of airflow optimisation? Here at Overclockers UK, we have a range of PC cases for every build you can think of!
More PC Case Content
Best PC Cases for the Office
Best PC Cases for Vertical GPU Mounting
Best PC Cases for Water Cooling
What’s Your PC Case Setup Like?
Content with your current build? Are you looking to upgrade and overhaul your system? Tell us all about it in the comments!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
