1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Upgrade advice
Discussion in 'New to PC gaming & upgrade advice' started by epeion, 18 Sep 2020.
  1. epeion
    hi need advice on best option to go for, i currently using an AMD FX 8350 and 12GB of ram, i have been offered below by my brother who has just done an upgrade of his own rig.
    MSI X370 XPower Gaming Titanium and AMD 1700X for £200
    i know i will also need new ram so this will add about £60 for 16GB to the total, what i was wanting advice on was weather it would be better to and also viable to say spend about £350 max and get something more upto date including ram in that figure.
    Thank you
  2. dfour
    Wise Guy
    With a ryzen 5 3600 running about £200 (not from OC unfortunatly) and the ram £60 for the cheapest 3200mhz only leaves £100 for a motherboard.
    My basket at Overclockers UK:
    Total: £379.47 (includes shipping: £10.50)
    [​IMG][​IMG][​IMG]
    cheaper. Maxt will be fine in a atx case.
    Total: £359.46 (includes shipping: £10.50)
    [​IMG][​IMG][​IMG]
    Again the 3600 can be had for cheaper​
  3. dfour
    Wise Guy
    tidying up
  4. dfour
    Wise Guy
  5. epeion
    thanks the the advice dfour will have a closer look at that shopping basket
  6. lee32uk
    Underboss
    I would avoid both of those Asus boards listed above. The B450 TUF has a flimsy VRM and the B450M-K is even worse.
  7. lee32uk
    Underboss
  8. epeion
    cool will take that into consideration thank you
  9. epeion
    so found the below bundle for £ 339.98 any good ?
    MSI AMD B450 TOMAHAWK MAX ATX Motherboard
    AMD Ryzen 5 3600
    Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16 Memory Kit
    or the above with below M/B
    ASUS ROG STRIX B450-F GAMING Motherboard
  10. EsaT
    Sgarrista
    MSI is the only maker who has confirmed Zen3 support for B450 boards.
    Also MSI is the only maker who put effort into CPU VRMs in them.
    That Asus board is complete brand hype fraud and scam with VRM good only for 65W TDP CPUs.
  11. epeion
    cool thanks for the info EsaT
  12. Shaolin Chicken
    Wise Guy
    Whats wrong with the MSI X370 XPower Gaming Titanium motherboard?
    I'd just upgrade to a Ryzen 3600 and 16GB of ram, will be a nice upgrade for the op.
  13. lee32uk
    Underboss
    He would have to buy the board off his Brother.
  14. Shaolin Chicken
    Wise Guy
    Oh right, now I see, thanks.
  15. epeion
    ok just to give and thank everyone who posted, ive done a bit more research and am likely to pull the trigger on the below for £394 as MSI are doing a £45 cash back offer so gets me to my original budget of £350
    MSI MPG B550 GAMING PLUS AMD Motherboard
    AMD Ryzen 5 3600
    Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3600MHz Memory Kit
    so only £10 more than my original bundle, unless of course anyone can see anything wrong with this bundle?
  16. jigger
    Capodecina
  17. dfour
    Wise Guy
    Only issue is OC are out of stock on the motherboard and overpriced on all there 3600 chips.
    You can save the extra tenner by swapping the ram to
    Total: £73.69 (includes shipping: £8.70)
    I would ignore the a520 chipset if your looking for any futre proofing as it doesnt support pcie4 (yes I know it doesnt do much now even with the 3080) but it could in the furure and it also doesnt support overclocking and has less usb support than b550 etc. ​
  18. epeion
    thanks for the reply i thought the same about the a520 chipset, yes the bundle has a better CPU but its not worth the cost difference so unless thing change will go for the B550 bundle i looked at for £349 including MSI cash back offer from else where, would have got it here if price was better on 3600 chips
