Looking to cool your PC in 2026? Well, I mean, I hope you are… In this article, we’re taking a look at some of the best PC fans you can grab this year. From RGB to understated grown-up fans for those minimalist builds, we’ve got you covered. Let’s get that airflow going!
Cringe introduction aside, the humble PC fan often gets overlooked. People tend to focus on the flashy parts while forgetting that cooling is key to keeping everything running smoothly. A good fan can make all the difference, whether you’re trying to squeeze out a bit more performance, keep things quiet, or just prevent your system from melting into a puddle of molten metal. No Terminator endings in here, please.
APNX FP1-RQ Performance Reverse Blade ARGB Fan
The APNX FP1-RQ 120mm PWM ARGB Fan delivers quiet, efficient cooling with its reverse blade design. Operating between 300 and 1200 RPM, it offers great airflow with minimal noise, making it ideal for quieter systems. Whether you’re looking to light up your build with ARGB lighting or boost cooling, this fan has got you covered. Plus, it’s available in both black and white!
At 30mm thick, the APNX FP1-RQ outperforms its 25mm counterparts by offering better airflow and heat dissipation. Plus, the ultra-thick shock-absorbing pads keep everything stable, and the hydraulic bearing ensures long-lasting durability.
APNX FP1-RQ Performance Reverse Flow ARGB 120mm PWM Fan – Black
COO-APN-04028
£12.95 GBP £ 2.99 GBP
-76.91%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETLian Li UNI FAN TL LCD Wireless
The Lian Li UNI FAN TL LCD Wireless is a game-changer for those who want performance, style, and simplicity. These fans feature daisy-chain technology and 2.4GHz wireless connectivity, so you only need one cable to power and control up to four fans. Whether you’re after stunning RGB effects or need solid cooling, the UNI FAN TL delivers with up to 62 CFM of airflow and 2.9mmH2O static pressure. Plus, at 27dB, they run super quiet!
Available as singles in black or white, or in a triple pack complete with the 2.4GHz wireless controller, Lian Li has once again surpassed the competition with new tech and aesthetics. They’re also available in reverse, allowing you to push or pull air in the opposite direction while keeping the LCD screen facing the correct way.
TRYX ROTA SL Fan
Ready to take your cooling to the next level? The TRYX ROTA SL ARGB 120mm Fan, available in both black or white, is all about high airflow and low noise. This fan produces 65.64CFM airflow and 2.49mmAq static pressure at just 28.87dBA, making them perfect for everything from case ventilation to radiator cooling.
With specialised fan blades for strength and durability, the ROTA SL offers top-notch airflow while keeping noise to a minimum. Plus, the fluid dynamic bearing and three-phase six-pole motor keep things smooth and silent, even when cranked up to full speed. What’s more, there are shock-absorbing pads to reduce vibrations, keeping everything quiet and stable, even during intense gaming sessions.
TRYX ROTA SL 120 ARGB Black Triple Fan Pack – 120mm
COO-TRX-05469
£59.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
TRYX ROTA SL 120 ARGB White Triple Fan Pack – 120mm
COO-TRX-05470
£59.99 GBP £ 34.99 GBP
-41.67%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETCorsair LX120-R RGB – Reverse It and Revel in the Glow
The second reverse fan in our line up, the Corsair LX120-R RGB, flips the script literally! Designed with a reverse rotor, this 120mm PWM fan ensures that your RGB lighting stays fully visible, even when used for intake. Available in black or white, as well as a 140mm variant, this fan is the perfect addition to your PC.
More than just a looker, the LX120-R packs serious cooling power. Spinning at up to 2,400 RPM, it delivers 67CFM airflow and a hefty 5.53mm H2O static pressure, making it ideal for high-performance builds. Corsair’s Magnetic Dome bearings keep things whisper-quiet while ensuring a long lifespan. Plus, with iCUE LINK integration, you can connect multiple fans in a seamless block, cutting down on annoying cable management. There’s even a Zero RPM mode for silent operation when your PC is idle.
CORSAIR LX120-R RGB 120mm PWM Reverse Fan – Black
COO-CRS-03523
£34.99 GBP
(incl. VAT)
FREE SHIPPING
Pre order
ADD TO BASKET
CORSAIR ICUE LINK LX120-R RGB 120mm PWM Reverse Fans Starter Kit – White
COO-CRS-03526
£109.99 GBP £ 69.95 GBP
-36.4%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
CORSAIR LX140-R RGB 140mm PWM Reverse Fan – White
COO-CRS-03529
£39.95 GBP £ 24.95 GBP
-37.55%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETbe quiet! Light Wings LX ARGB – Silent Power
Designed for showcase builds, the be quiet! Light Wings LX ARGB is more than just a fan! It’s the centrepiece of your case. With a unique illuminated hub and frosted fan blades, this 120mm PWM high-speed fan delivers stunning lighting effects that make any PC stand out. Available in black or white, as a single fan or a triple pack, and with a 140mm variant for those who want even more airflow, the Light Wings LX ARGB is an incredible choice.
Engineered for performance, the Light Wings LX ARGB 120mm features nine optimised fan blades that generate high static pressure of 2.51mm H2O, making it ideal for radiators, air coolers, and airflow-focused cases. Its closed-loop motor technology ensures that the fan maintains consistent RPM, even under varying resistance. Plus, the rifle-bearing design extends the fan’s lifespan up to 60,000 hours, keeping your system cool and quiet for years to come.
Be Quiet Light Wings LX ARGB 140mm PWM High Speed Triple Fan Pack – White
COO-BEQ-03410
£39.95 GBP £ 28.99 GBP
-27.43%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Be Quiet Light Wings LX ARGB 140mm PWM High Speed Triple Fan Pack – Black
COO-BEQ-03409
£39.95 GBP £ 34.99 GBP
-12.42%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Be Quiet Light Wings LX ARGB 120mm PWM Fan
COO-BEQ-03399
£14.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Best of Hardware
Looking to upgrade your gaming PC with the best of the best? Head on over to our hardware guide and see what goodies are just waiting to be added to your set-up!
Shop PC Fans
If none of these beasts have caught your eye, then don’t panic! Overclockers UK has a huge range of PC fans for you to choose from.
Learn more About Your Cooling
Stay Cool, Stay Quiet
What fans are you rocking in 2026? Let us know in the comments below!
