Looking to build a powerful workstation that suits your creative or professional needs? Don’t have the right case for that must-have tech?
We’ve searched high and low across the Overclockers UK website and put together this list of the best PC cases for workstation PCs.
Best PC Cases for Workstation PCs Key Takeaways
- Workstation PCs are computers optimised for professional applications such as video editing, 3D rendering, CAD, AI, and more.
- Workstation PCs will generally feature specialised hardware such as high-end CPUs like the AMD Threadripper Series, large amounts of RAM, and powerful GPUs.
- Many workstations are built within large Full-Tower PC cases which offer ample room for top-tier components and multi-GPU set-ups.
- Workstation cases are available from a range of manufacturers including Phanteks, Lian Li, Corsair, Jonsbo, and more.
What is a Workstation PC?
A workstation PC is a type of computer designed for high-performance professional applications, such as 3D rendering, simulations, CAD programming, AI, and more. A workstation PC harnesses specialised components, including professional CPUs like the AMD Threadripper Series, workstation GPUs such as NVIDIA RTX 6000 Ada graphics cards, high-capacity RAM, and ample onboard storage. All of which delivers unparalleled performance, backed up by an enhanced cooling solution that keeps excess heat to a minimum.
This powerhouse hardware is typically installed within a robust full tower chassis, often supporting dual chamber designs or multi-GPU set-ups to support all your professional workloads.
Our Top PC Cases for Workstation PCs
Struggling to find the ideal PC case to build your professional workstation? We’ve rounded up five spectacular models you can check out below.
Phanteks NV7 DRGB Full Tower Black PC Case
The Phanteks NV7 comes equipped with everything you need to build the workstation of your dreams, boasting ample support for a huge range of modern-day hardware. Designed to accommodate large components such as E-ATX motherboards and GPUs up to 450mm long, the Phanteks NV7 is the perfect foundation for your workstation PC. All of which will be kept cool and quiet thanks to extensive compatibility with a range of cooling solutions, including twelve fans, multiple radiators, and even custom water-cooling loops. The seamless front and side tempered glass panels allow you to display all your flagship hardware with pride, illuminated in the vibrant RGB, customisable via the included D-RGB controller.
Phanteks NV7 D-RGB With Front And Side Glass Panels Full Tower Case – Black
CA-0BQ-PT
£189.95 GBP £ 159.95 GBP
-15.79%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETLian Li Lancool III Full Tower PC Case – White
The Lian Li Lancool III is another fantastic choice for those looking to build a workstation PC. This chassis is designed with a heavy focus on optimised cooling, featuring large high-porosity mesh panels, excellent support for fans and radiators, and mounting points for custom loop hardware. What’s more, you can easily install powerful professional hardware inside this case, as there is room for E-ATX motherboards under 280mm wide, eight PCIe slots, a 420mm GPU clearance, and room for PSUs up to 220mm long. Furthermore, with the ability to hold up to twelve 2.5” SSDs, you can easily build a workstation with a phenomenal storage solution, perfect for working on any projects big or small.
CA-7AX-LL
£139.99 GBP £ 109.96 GBP
-21.45%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETPhanteks Enthoo Pro Full Tower Case – Black
Next up on our list is the Phanteks Enthoo Pro. This is another full tower chassis that’s been designed to support multiple configurations, thanks to its large internal capacity. Compatibility with up to SSI-EEB motherboards, 427mm long graphics cards, ten 120mm fans, and even eleven SSDs, the Phanteks Enthoo Pro provides you with everything you need to build a showstopping workstation. Plus, the sleek all-black look means this case will seamlessly blending into the rest of your hardware.
CA-003-PT
£119.99 GBP
(incl. VAT)
FREE SHIPPING
Pre order
ADD TO BASKETFractal Design Pop XL Silent Black Solid Full Tower Case – Black
For those wishing to build a powerful yet subtle workstation, we recommend the Fractal Design Pop XL. This large full tower case offers amazing support for all your hardware, with a main chamber that can accommodate E-ATX motherboards, multiple 430mm long GPUs, and 185mm tall CPU coolers. What’s more, with its versatile drive compatibility, you can easily build a comprehensive storage solution for your workstation. Furthermore, this sleek and stylish case boasts a clever addition hidden behind the powder coated panels. Concealed by a magnetic plate are two 5.25″ drive bays, allowing you to install a pair of optical drives in this chassis. Perfect for creatives that still work with physical media.
CA-0AE-FD
£99.95 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETAntec 900 E-ATX High Performance Workstation Full Tower Case
Last, but not least, we recommend the Antec 900. Based on the classic design, this chassis offers an incredible combination of high-airflow, superior hardware support, and stylish looks. The spacious interior is designed to facilitate powerful components, such as SSI-EEB motherboards, AMD Threadripper processors, and multiple high-end GPUs. Furthermore, you’ll have plenty of options when it comes to storage solutions, as the Antec 900 offers nine drive bays capable of supporting five 3.5″ HDDs and four 2.5″ SSDs. Any workstation built inside this incredible chassis will also boast excellent cooling straight off the bat, as it comes with six pre-installed fans to create optimum airflow through both the main and PSU chamber.
CAS-ATC-07636
£249.95 GBP £ 229.99 GBP
-7.99%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETExplore Even More Workstation Cases
If the models we’ve highlighted don’t suit your professional needs, you can explore all our other Full Towers with the click of a button.
Best PC Cases for Workstation PCs FAQ
What is a workstation?
Workstations are computers that are optimised for professional tasks, such as video editing, CAD, AI modelling, scientific simulations, 3D rendering, and more.
What hardware is needed for a workstation PC?
Most professional workstations are equipped with powerful high-end components. This can include professional CPUs like the AMD Threadripper or Intel Xeon Series. Additionally, they generally feature a larger form factor motherboard, such as SSI-EEB or E-ATX, and one or more powerful graphics cards. Additionally, a workstation will require large amounts of storage space, so will come with multiple HDDs and SSDs.
What size cases do workstations use?
In order to support the premium hardware configurations used in a workstation PC, you’ll need a larger case. As such, you’ll want to opt for a full tower design for optimum compatibility.
How much cooling does a workstation PC require?
Workstation computers feature powerful hardware that will generate significant waste heat. This means you’ll require robust thermal solutions to maintain them at optimum temperatures. As such, most workstation cases offer excellent support for a variety of cooling hardware, including multiple fans, radiators, and even custom water loops.
Expand Your Professional Workloads
Share Your Workstation PC Case Recs!
Do you have a workstation PC? What case are you using to house all that powerful tech? Share your top recs in the comments below!
