Variable Refresh Rate (VRR) technology is well worth enabling if you’re trying to elevate your PC gaming skills and experiences. Once toggled on, much of your gameplay feels perfectly synchronised, which is certainly no accident!
Setbacks like screen tearing and stuttering can pull victory from your grasp during countless gaming moments. However, in place of bitterly grunting ‘grr’ when the Defeat card flashes up, you could instead harness VRR to better your chances of clinching the next win. The stars will finally align… or at least your frame rates will! Here’s what VRR technology is in all its forms, as well as how to enable it!
How to Enable Variable Refresh Rate Technology Key Takeaways
- VRR stands for Variable Refresh Rate technology.
- Each version of VRR aims to synchronise your monitor’s refresh rate with your GPU’s frame output, helping to reduce screen tearing, stuttering, and similar visual anomalies.
- The three VRR technologies to remember are Adaptive Sync, AMD FreeSync, and NVIDIA G-SYNC. Adaptive Sync and FreeSync work similarly, while G-SYNC largely works differently due to a module in affected monitors.
- Both FreeSync and G-SYNC have essential hardware requirements to adhere to.
- Before attempting to enable VRR, it is recommended that you do preliminary checks first; double-checking which tech your monitor supports, downloading the NVIDIA App and AMD Software: Adrenalin Edition, adjusting in-game settings, etc.
What is VRR?
VRR stands for Variable Refresh Rate technology. Unlike fixed rate monitors locked in at static frequencies like 60Hz or 144Hz, VRR-enabled monitors are always operating in real time to ensure the display keeps up with the GPU’s frame output. As a result, stuttering and screen tearing can be eliminated from gameplay.
Games noticeably play smoother with VRR, making them easier for players to read from frame to frame. It’s total clarity, both in terms of what’s displayed onscreen and how your brain comprehends it, directly influencing the acuity of your reflexes and strategies!
To date, there are two main types of VRR technology to utilise: NVIDIA G-Sync and AMD FreeSync. There’s also Adaptive Sync, which preceded our main two but soon became eclipsed in capability. Still, while they each share the same end goal, how they get there is decidedly different, especially in terms of their hardware requirements. The general consensus is that NVIDIA G-SYNC offers the best performance out of the three but is also typically the most expensive. It charts its own path away from Adaptive Sync, whereas AMD adopts that technology and enhances it with FreeSync.
Still, the manufacturers want consumers to have more choice, and some of these brands have been collaborating to make their tech compatible, which also makes ‘better/worse’ comparisons less black and white. So, here’s a brief summary of how these VRR technologies work, and tables of their required hardware specifications where applicable:
Adaptive Sync
Adaptive Sync is an open industry standard VRR technology built with the DisplayPort 1.2a specification as its foundation. It was an upgrade over V-Sync technology.
While no proprietary module is required for Adaptive Sync to function, a DisplayPort 1.2a cable is still needed, alongside a GTX Series 10 GPU or later. As a result, monitors with Adaptive Sync can be lower in price.
Adaptive Sync is relatively obsolete on its own. However, it gave rise to FreeSync, and so its presence is still acutely felt in the VRR space.
FreeSync
AMD adopted VESA’s Adaptive Sync standard to develop FreeSync, and has moved beyond its initial reliance on the DisplayPort 1.2a connection. Compatible HDMI displays are now supported, too.
Once again, there’s no costly hardware module. Instead, this software utilises an open source ecosystem with an absence of licensing fees. This allows the technology to be more affordably incorporated into a wider range of monitors. FreeSync is only usable with GPUs from the Radeon RX 200 Series and later.
AMD FreeSync Hardware Requirements
| Component | FreeSync Requirements |
| Operating System | Windows 7-11 |
| Graphics Card | FreeSync-compatible GPU – Radeon RX 200 Series or higher |
| Software | The latest AMD Radeon Graphics Drivers |
| Monitor | An AMD FreeSync-compatible monitor connected via DisplayPort or HDMI. |
What is G-SYNC?
G-SYNC is a technology that integrates dedicated hardware modules inside compatible NVIDIA monitors, so its path branches off wildly from Adaptive Sync and FreeSync. These powerful modules communicate with the CPU to synchronise the display’s refresh rate with the GPU’s frame output.
G-SYNC supports a wide range of older NVIDIA graphics cards, but the module and further hardware requirements can make these screens more expensive.
NVIDIA G-SYNC Hardware Requirements
| Component | G-SYNC Requirements |
| Operating System | Windows 11 / 11 / 8 / 7 |
| Graphics Card | G-Sync compatible GPU GeForce GTX 650 Ti Boost or higher |
| Software | The latest NVIDIA GPU drivers |
| Monitor | A G-Sync-compatible monitor connected via DisplayPort. |
| G-SYNC Pulsar | Pulsar-Enabled monitor DisplayPort 1.2+ |
There’s also G-SYNC Compatible, a separate technology that rolled out in 2019 and doesn’t include the NVIDIA G-SYNC processor. This amendment allowed people to enable G-SYNC on monitors that traditionally only allowed AMD FreeSync, even if the results aren’t as spectacular as the module-included displays. That said, the scope of G-SYNC-enabled monitors is widened, and these displays are now commonly available.
Can’t decide whether you should use FreeSync or G-SYNC? Perhaps our insights over here will help.
How to Enable VRR
So, now you know what VRR strives to achieve. Let’s start doing all the preliminary checks and gear up to enable VRR!
Start by following this pathway to enable VRR in Windows:
Click Start > System > Display > Graphics > Toggle Variable refresh rate On.
This will get your PC poised for supporting any VRR changes you’ll imminently make elsewhere. There’s more to do yet!
Next, check which VRR technology your monitor supports: FreeSync or G-SYNC. That way, you can avoid sinking time into unnecessary red herrings. Check the user manuals for your display or trace your way back to the product page via your internet history or email receipts. Or you can Google the make and model of the display, or look for the corresponding information somewhere on your monitor (usually the back). An onscreen menu might also display this information. Wherever you find the relevant data, it should clarify what to expect.
Once you know whether your monitor supports FreeSync or G-SYNC, download either the NVIDIA App or AMD Adrenalin: Software Edition so that you can update your drivers and any other key bits of software. That will make VRR tech, as well as many other aspects of your gaming, function more smoothly. For example, NVIDIA Reflex can facilitate ultra-low latency, which pairs nicely with VRR.
It’s also worth dipping into your game settings beforehand. Remember, VRR technology is only advantageous if your favourite titles are running more slowly than the refresh rate of your monitor. Should you be trying to play them beyond the maximum, VRR’s efforts are basically undermined, so adjust any values there as you need to. Ideally, in-game frames need to be at least four frames below your monitor’s maximum refresh rate.
Now let’s get into the step-by-step of enabling G-SYNC and FreeSync.
Enabling G-SYNC
In most cases, G-SYNC is enabled on compatible NVIDIA displays by default. However, in the rare event yours is not, or that you need to double-check or make amendments to its activation protocols, you can quickly review the situation in the NVIDIA Control Panel.
To ensure G-SYNC is enabled, follow this simple pathway:
- Click Start
- Search for the NVIDIA Control Panel and open the app
- Look under Display in the leftmost column
- Click Set up G-SYNC
- Tick the Enable G-SYNC/G-SYNC Compatible box
- Select the display to apply the G-SYNC settings
- Choose between Full screen mode and Windowed and full screen mode
- Follow the subsequent instructions until set-up is complete
We recommend being careful with the screen modes in particular and testing out the results. That’s because, depending on your hardware and monitor, G-SYNC may not adapt well to the windowed format. However, full screen is considered to be reliable.
Should you wish to enable G-SYNC on individual games, such as on single-player titles but not multi-player, you can start from the NVIDIA Control Panel and:
Click Manage 3D Settings > Program Settings > Monitor Technology > Adjust your games as needed.
Enabling FreeSync
Once again, FreeSync should be automatically enabled on systems where a compatible AMD GPU and monitor are being used. That said, you can still check things out and make whatever changes you need to.
To check FreeSync is enabled or to amend relevant values, follow this pathway:
- Click Start
- Input AMD Software into the search field
- Select AMD Software: Adrenalin Edition
- Type Display into the bar at the top right of the UI
- Select the Display Settings result
- Navigate to Global Display
- Check that AMD FreeSync is toggled on
You can also review the supported FreeSync range in this window and make any amendments you need to. If you prefer, you’re also able to adjust when FreeSync is activated in each of your games as well.
Ready to Use VRR?
Unsure if your current set-up can keep up with VRR’s sweeping results? Here at Overclockers UK, we have a range of fiercely powerful NVIDIA- and AMD-powered gaming PCs, along with the silky smooth FreeSync and G-SYNC displays to go with them. Enjoy fluid frames like never before! Click the buttons below to take full stock of our offerings or scroll a smidgen further for some prized picks.
OcUK Gaming Mach 1.1 – Ryzen 5600 RTX 5060 Pre-Built Gaming PC
FS-PB14-EP
£1099.99 GBP £ 969.95 GBP
-11.82%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
OcUK Gaming Domino – Ryzen 7 9800X3D RX 9070 XT Pre-Built Gaming PC
FS-PB18-EP
£2699.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
OcUK Gaming Indigo – GeForce RTX 5080 Pre-Built Gaming PC
FS-1DN-EP
£3299.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
MSI MPG 491CQPX QD-OLED 49″ 5120×1440 240Hz 0.03ms A-Sync Curved HDMI 2.1 Ultrawide Gaming Monitor
MON-MSI-05475
£998.99 GBP £ 748.99 GBP
-25.03%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
MSI MPG 341CQR QD-OLED X36 34″ 3440 X 1440 360Hz 0.03ms Adaptive-Sync Curved Ultrawide Gaming Monitor
MON-MSI-07048
£998.99 GBP £ 798.95 GBP
-20.02%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
LG UltraGear GX9 5K2K 45GX950A-B 45″ WOLED 5120×2160 165Hz 0.03ms FreeSync G-Sync Compatible USB-C HDMI 2.1 DP 2.1 800R Curved Ultrawide Gaming Monitor
MON-LGC-05059
£1749.95 GBP £ 1298.99 GBP
-25.77%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETHow to Enable Variable Refresh Rate Technology FAQ
What does VRR stand for?
What is Variable Refresh Rate technology?
Variable Refresh Rate technology synchronises your monitor’s refresh rate with your GPU’s frame output. There are three versions of the technology that take different approaches to this objective: Adaptive Sync, AMD FreeSync, and NVIDIA G-SYNC.
How can I check if my monitor supports VRR?
You can check if your monitor supports VRR by reviewing the product specifications on the manufacturer’s website or in your user manual.
Is G-SYNC better than FreeSync?
In terms of performance, NVIDIA G-SYNC is considered to be better thanks to its dedicated hardware modules. However, AMD FreeSync displays are more affordable and widely available. That said, the best option for you depends on your circumstances and preferences.
How do I enable VRR in Windows?
To enable VRR in Windows, navigate to Start > Settings > System > Display > Graphics. Look for the Variable Refresh Rate option and toggle it on if your hardware and Windows version support it.
How do I enable NVIDIA G-SYNC?
If you’re trying to enable G-SYNC, open the NVIDIA Control Panel and navigate to Display > Set up G-SYNC and tick the Enable G-SYNC/G-SYNC compatible box. You can then select your compatible monitor and choose whether to enable it for full-screen more or both windowed and full-screen modes.
How do I enable AMD FreeSync?
Should you wish to enable FreeSync, open the AMD Software: Adrenalin Edition software. Then navigate to Settings > Display. Under Global Settings, look for the AMD FreeSync option and toggle it on. Double-check that your monitor is connected using a DisplayPort or HDMI connection, too.
More Monitor Content
Do You Use VRR?
How do you find using VRR? Do you prefer FreeSync or G-SYNC? Share your thoughts with us in the comments.
